15x7.5 38+ on ek hatch?
Old Oct 2, 2006 | 09:37 AM
Krucial_Ek9's Avatar
Default 15x7.5 38+ on ek hatch?
hey i was wondering if 15x7.5 work on my ek hatch? any help will be appreicated
Old Oct 2, 2006 | 10:22 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 15x7.5 38+ on ek hatch? (Krucial_Ek9)
No. The 15" tire sizes for your car - 195/55-15 or 205/50-15 - are usually NOT approved for mounting on a 15x7.5 wheel. Stick with 15x6 or 15x6.5 and you'll be fine.
Old Oct 2, 2006 | 10:52 AM
^^ thanxs that sucks cause i really wanted the drag dr-20's but they only come in 15x7.5
Old Oct 3, 2006 | 11:12 AM
jiggatone's Avatar
lol i was lookin at the same thing just now on ebay was gonna order a set too damn
Old Oct 4, 2006 | 09:36 PM
pushlatency's Avatar
Default Re: (tonEK)
Actually, i'm curious, will 15x7 with a +38 offset cause any problems with an EK hatch?
Thanks
Old Oct 4, 2006 | 09:52 PM
vtecsi00's Avatar
Default Re: (pushlatency)
no
Old Oct 6, 2006 | 05:40 AM
96GSRcx's Avatar
Default Re: 15x7.5 38+ on ek hatch? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">No. The 15" tire sizes for your car - 195/55-15 or 205/50-15 - are usually NOT approved for mounting on a 15x7.5 wheel. Stick with 15x6 or 15x6.5 and you'll be fine.
I'm not saying you're wrong, but isn't that what tire stretch is all about? (serious question) It might not be what is recommended, but since when do people people on honda-tech read or follow directions
Old Oct 6, 2006 | 10:40 AM
vtecsi00's Avatar
Default Re: 15x7.5 38+ on ek hatch? (96GSRcx)
that size tire is for a 15x6 to 15x7 wheel.......stretch look is for vw boys....
problem with tha look is that you are expossing the wheel to curb issues and premature wear on the tire..........
Old Oct 6, 2006 | 11:56 AM
Furyof4's Avatar
Default Re: 15x7.5 38+ on ek hatch? (vtecsi00)
Depending on which tire you plan on using, 7.5 may work fine. Its very common for autox'ers to put Azenis on a 7.5" wheel with great results so I'm sure others may work also.
Old Oct 6, 2006 | 01:47 PM
FalkenSiR's Avatar
Default Re: 15x7.5 38+ on ek hatch? (Furyof4)
They will fit fine as long as you're not too low. That is your answer, now is it the best size for you car? nope.
Old Oct 6, 2006 | 04:46 PM
96GSRcx's Avatar
Default Re: 15x7.5 38+ on ek hatch? (fast95eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 &raquo;</TD></TR><TR><TD CLASS="quote">They will fit fine as long as you're not too low. That is your answer, now is it the best size for you car? nope.</TD></TR></TABLE>
I am honestly not trying to be a jerk, but why would you say something like that, then not express to him what size you "think" he needs? You could say "what look are you going for?" "Do you just like the wheels?" or just give a suggestion. Why didn't you just end your phrase with "You Suck!"
Old Oct 6, 2006 | 05:56 PM
96GSRcx's Avatar
This is for the person who asked about 15x7s. Just like everyone says, They fit fine as long as you don't try to put 225/50/15s on em. Then you have to roll, shave, and flare the front fenders. Here's a pic of them before any fender mods. http://members.aol.com/vtec2001civic/225.jpg
Old Oct 7, 2006 | 06:03 AM
old man neri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96GSRcx &raquo;</TD></TR><TR><TD CLASS="quote">This is for the person who asked about 15x7s. Just like everyone says, They fit fine as long as you don't try to put 225/50/15s on em. Then you have to roll, shave, and flare the front fenders. Here's a pic of them before any fender mods. http://members.aol.com/vtec2001civic/225.jpg</TD></TR></TABLE>
Ya, sure, you can fit them in there. The problem is that is is the wrong size tire for that car. The correct 15" tire for that car is not meant to go on a 15X7. Ken's post (the second one) explained it perfectly.
If you have the wrong size tire on you can run into rubbing issues, the speedo will be way off, the acceleration will also suffer. There is no advantage to running a rim that wide on that car.
Old Oct 7, 2006 | 01:20 PM
96GSRcx's Avatar
Default Re: 15x7.5 38+ on ek hatch? (old man neri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">
Ya, sure, you can fit them in there. The problem is that is is the wrong size tire for that car. </TD></TR></TABLE>
I'm pretty sure I said don't try to run 225 tires. And as for my car. With the swap I have, it's the correct size.
The correct 15" tire for that car is not meant to go on a 15X7. Ken's post (the second one) explained it perfectly.</TD></TR></TABLE>
Did you mean 15x7.5? because the tire sizes he quoted would work fine on a 15x7 wheel.
If you have the wrong size tire on you can run into rubbing issues, the speedo will be way off, the acceleration will also suffer. There is no advantage to running a rim that wide on that car.</TD></TR></TABLE>
These two statements have no right to follow one another. First sentence is slightly true. 1st -Tire rub is bad -true- 2nd speedo will be way off-false- That would depend on what tire you are running. If you know how tire sizes work, then selecting the right tire will not make your speedo be off. 3rd-acceleration will suffer -not totally true- that's one of those it could go either way things depending on what tire size you choose.
Are you still talking about 15x7 or 15x7.5?
If you're talking about 15x7, then there's also no disadvantage to running them.
If you're takling about 15x7.5 the only advantage would be being able to run a wider slick, which he's not.
Old Oct 11, 2006 | 01:12 PM
EK tommy's Avatar
DAMN! i wanted to get the drag dr20s too.
J.HA
Oct 1, 2010 10:44 AM
grandam
Oct 26, 2007 05:48 PM
FUPAH8TR
Jul 2, 2007 06:52 PM
AcuraRacer112
Feb 13, 2006 09:15 PM
