Just Finished Painting My Car, Wet Sand?
Old Oct 2, 2006 | 08:48 AM
alupso's Avatar
Default Just Finished Painting My Car, Wet Sand?
I just finished painting my car on Saturday and overall it turned out pretty good but it has a couple of problems.
Most of the paint looks good but on some spots it looks a little dull and there is a little orange peel. I was wondering if there would be anyway to remove the dullness by either wet sanding or maybe buffing and polishing.
I would rather not have to wet sand since this is kind of my first paint job and I’m not very experienced.
If I was able to buff it out what kind of compounds and polishing pads would be best?
Also, disregard the dents and lack of body work as this is just a hobby and I was just messing around to see what would turn out.
Old Oct 2, 2006 | 09:04 AM
toyomatt84's Avatar
Sanji
Wetsanding isn't all that difficult, as long as you put enough paint down to not wear through it all in one sanding.
Old Oct 2, 2006 | 09:07 AM
alupso's Avatar
What about buffing it afterwards and what kind of compunds and pads should be used?
Old Oct 2, 2006 | 09:08 AM
WhiteSlips's Avatar
Default Re: (toyomatt84)
Definitely needs to be wetsanded, as long as you put clear on it. If it's just a base coat black paintjob, just get it buffed. If you wetsand it, then get it buffed also.
Old Oct 2, 2006 | 09:11 AM
alupso's Avatar
Default Re: (crstfr14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crstfr14 &raquo;</TD></TR><TR><TD CLASS="quote">Definitely needs to be wetsanded, as long as you put clear on it. If it's just a base coat black paintjob, just get it buffed. If you wetsand it, then get it buffed also.</TD></TR></TABLE>
Yeah its's got about 2-3 coats of clear.
Old Oct 2, 2006 | 02:03 PM
alupso's Avatar
Would anybody have any information about the correct compounds and pads to use after doing the wet sanding to buff out the paint?
Old Oct 2, 2006 | 02:45 PM
tnbigdawg's Avatar
Default Re: (alupso)
Okay since you've got it clear coated.....
The goal is to make the buffing process easier since it's a black color:
Do your hard work sanding first. I mean sand it with a rougher grit paper depending on how textured the clear is, and work your way up to the FINEST grit possible(This last sanding step is important). Something like 1000/1200/1500-2000+ paper. 1000 might be too aggressive but it cuts out waves, and again it depends on the texture.
Because you sanded with such a fine grit paper(greater than 2000 grit) you will spend less time trying to buff out scratches and less chance of burning through.
The following is just a guidline since every autobody technician has their own techniques:
I use 3M products for the cut and buff. Depending on how long the paint has been cured:
3M Perfect-it III Ultra-Cut Rubbing Compound for fully cured/hardened paint. Use with a DAMP wool pad(Or foam if you've had experience).
or
3M Perfect-it II Compound for fresher paints. Use with a DAMP wool pad(Or foam if you've had experience).
Then you'll need a machine polish with a CLEAN/NEW foam pad. Experiment with different brands/products.
Then you can use a hand glaze if you want to. If the paint has cured for 2+ months then you can use a wax instead.
inh
Paint and Body
Jul 11, 2011 01:44 PM
b16-t
Paint and Body
50
May 10, 2008 08:49 PM
rockofcali
Paint and Body
30
Apr 5, 2008 03:55 AM
ontheline
Paint and Body
16
Mar 9, 2008 07:08 PM
RacerBoy
Jan 13, 2003 08:24 PM
