is anyone elses like this? CRX info
Old Oct 2, 2006 | 06:31 AM
rewerbcrx's Avatar
Default is anyone elses like this? CRX info
i just was able to get my car on the road at the end of aug. and i only drive on the weekends ( i work away from home during the week)
b18a engine (11:5:1 compression) in a 91 crx hf
there is a serious vibration (inside the car)... but outside the car you can't even tell the car is running... is this common for the swaps?
and steering is less than desirable ( its really squirrly around 120, so i am affraid to take it over it) really squirrly!) if i was to try and take a slight corner at 120 i wouldn't be able to move the steering wheel more than a 1/16th of an inch
i know slow down (i really don't drive that fast all the time)... but i would still like to see what the top is on her
Old Oct 2, 2006 | 06:34 AM
crxnj's Avatar
Default Re: is anyone elses like this? CRX info (rewerbcrx)
most mount kits for the b-series are solid mounts so you'll get alot alot of vibration,,sounds like bass inside,dash is rattling at idle..its normal...for the steering its an old *** car ,,so get a new bushing kit to help bring back the steering
Old Oct 2, 2006 | 06:48 AM
category5 SI's Avatar
Default Re: is anyone elses like this? CRX info (Mr.speaker)
Ihave a jdm b16 it does the same thing,rattles alot,after a while you won;t even notice it.
Old Oct 2, 2006 | 06:53 AM
'90crxSI's Avatar
Default Re: is anyone elses like this? CRX info (category5 SI)
check your grounding straps. No joke, if there jacked, your car will vibrate... Also, make sure your spark plug cables are on there securely and in the right order.
Old Oct 2, 2006 | 07:35 AM
Suck my DX's Avatar
Default Re: is anyone elses like this? CRX info ('90crxSI)
im fully gutted and i got no rattles...jeeeyaaahhhh
Old Oct 2, 2006 | 07:38 AM
Loserkidwac's Avatar
Default Re: is anyone elses like this? CRX info (Suck my DX)
Fresh poly mounts will vibrate like hell give them a little and they will loosen up a tad, my car was pretty bad after my swap and I only drove mine on weekends like you, give it a few weeks and it should get a little better
Old Oct 2, 2006 | 09:04 AM
rewerbcrx's Avatar
Default Re: is anyone elses like this? CRX info (Loserkidwac)
thank you!
gsxr-t-bag600
Jan 7, 2013 02:08 AM
dethx88crx
Mar 9, 2008 07:46 PM
gpdxtrm
13
Dec 28, 2007 08:10 PM
efrex
Jan 19, 2006 09:35 AM
raene
24
Feb 17, 2003 12:43 PM
