what makes the motor have high rpm surge?
Old Oct 2, 2006 | 03:46 AM
superhatchbackbros's Avatar
Default what makes the motor have high rpm surge?
hey i just did a dp to mpfi swap on my 89 civic dx with a fresh d16y7, when i start the motor it has a high rpm surge like i tried the idel screw and vacuum lines etc and still have a high rev, i was wondering what causes this to happen. its up around like 2500-3 grand rpm i need to bring it down to like 1 grand, if anyone knows what could be making this happen please let me know so i can fix it thanks.
Old Oct 2, 2006 | 08:05 AM
Suck my DX's Avatar
Default Re: what makes the motor have high rpm surge? (superhatchbackbros)
it surges? or it stays that high?
could be an IM leak
Old Oct 2, 2006 | 08:23 AM
its stays kinda high, we adjust stuff and it it goes down a lil, i took it off my driveway and put it on flat gound and it went down to reg.. wierd. umm i dont think its a intake manifold leak. even tho i swaped it out i put new gaskets and **** all around , ughh how would i now for sure if it was tho?
Old Oct 2, 2006 | 08:32 AM
Jonknee's Avatar
Default Re: (superhatchbackbros)
Maybe bleed coolant, I dont know if that helps sorry.
Old Oct 2, 2006 | 09:19 AM
C_R_X_V_T_E_C's Avatar
Default Re: (La-Quiete)
IAVC, MAYBE
Old Oct 2, 2006 | 09:33 AM
SiMateoAko's Avatar
1) idle screw
2) did you swap the outter wires on the TPS sensor?
3) vacuum leak
Old Oct 2, 2006 | 09:35 AM
idel screw calms it down a lil, and yes we swaped the outter wires on the tps sensor and vacuum leak could be still possible.
Old Oct 2, 2006 | 10:37 AM
Suck my DX's Avatar
codes?
Old Oct 2, 2006 | 01:01 PM
SFlCrx's Avatar
check for cels but i'm 90 percent sure you have a vaccum leak of some sort check all the lines and makes sure everything is were it should be
Old Oct 2, 2006 | 09:10 PM
i tried so far my best on the vacuum leaks and also the ecu threw a error code 10 ( iat )
Old Oct 3, 2006 | 07:17 AM
4gencivicef9's Avatar
Default Re: (C_R_X_V_T_E_C)
IACV
do you have the right t.b.
Old Oct 3, 2006 | 07:18 AM
Default Re: (4gencivicef9)
fix codes then diagnose...
Old Oct 3, 2006 | 10:34 AM
i have a b18a1 tb on a z6 manifold. also i have a throttle spacer. but i doubt that would make this happen few of my friends have them and their car dont do this.
Old Oct 3, 2006 | 12:13 PM
okay do this and tell me if this fixes the problem....
take you air intake off so you can see your t.b. there should be a hole like a air port right before your butterfly put your finger over the hole and tell me if that stopped the surge if so...........put a piece rubber in the hole to block it off my buddie had a similar problem with his Z6
that is what I am talking about put your finger over it and see if that does it,,,
Modified by 4gencivicef9 at 1:25 PM 10/3/2006
Old Oct 5, 2006 | 05:53 AM
did that fix the problem.
Old Oct 5, 2006 | 06:51 AM
highrev1987's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gencivicef9 &raquo;</TD></TR><TR><TD CLASS="quote">okay do this and tell me if this fixes the problem....
Modified by 4gencivicef9 at 1:25 PM 10/3/2006</TD></TR></TABLE>
I definatly had that problem man look in the TB if there is two holes on the side closest to the firewall plug the lower one with your finger, it it goes down and starts sputtering then that the problem. its letting too much air in and the car idles high or surges depending on the ecu, with a obd0 it should stay high but with a obd1 it will surge i think.
Old Oct 7, 2006 | 10:50 PM
sorry i was out.. ya i already did that it has alot of vacuum and when i put my finger on it . it stops the surge.. and it was my fitv but now im geting a steady 3k start. and starys thier. i checked the iacv and cleaned it but just might be a bad sensor in the iacv.. so im going to try and get a new one.. but anymore info would help thanks..
Tyler Con
Dec 27, 2007 07:29 AM
happyabortion
Feb 18, 2006 06:16 PM
ajmj
Nov 22, 2005 05:12 AM
zcivicz
Mar 31, 2003 06:29 PM
t5er
Dec 15, 2002 07:25 AM
