Full Race Pro-am Stage 3 finally installed!!
Old Oct 2, 2006 | 02:00 AM
B20VTI's Avatar
Default Full Race Pro-am Stage 3 finally installed!!
Brilliant designed and engineered bit off kit, only problems i think i may have is fitting a filter on, will get around that some how..........
Anyways, il let the pics do the talking.
(will post more pics this evening when all vaccum lines and bumper is installed)
Old Oct 2, 2006 | 02:02 AM
KOREAN's Avatar
Default Re: Full Race Pro-am Stage 3 finally installed!! (B20VTI)
oOoo
Old Oct 2, 2006 | 03:05 AM
JDMroyEG5turbo's Avatar
Old Oct 2, 2006 | 03:25 AM
Sa.L.aS's Avatar
Carpe diem!
Old Oct 2, 2006 | 03:36 AM
B20VTI's Avatar
Default Re: Full Race Pro-am Stage 3 finally installed!! (Sa.L.aS)
Some engine specs -
Spec -
Benson sleeved 83mm B20 block
89mm Benson balanced and micropolished crank
CP 9-1 pistons/rings, Eagle 3/8 rods, ACL bearings
New OEM oil pump, new pick-up, new waterpump
ARP head studs and Cometic head gasket
New SuperTech valves, dual springs and titanium retainers
B16 VTEC head with 3 angle valve job, new seals, surfaced, all done by
PortFlow
CTR intake and exhaust cams, AEM 5 bolt cam gears
New STR fuel rail and new 1000cc RC Injectors
Edlebrock Victor X with stock throttle body, sensors and vtec selenoid
Oil pump adaptor with ls/vtec line in place
Distributor with new wires, MSD cap (external coil plug) and spark plugs (soon to be replaced with coil pack)
New timing belt, harmonic balancer
Brand new alternator
Quaife LSD
Driveshaft shop stage 3 driveshafts
Wilwood Brake kit
SPA gauges
Motec M4 pro ECU
Built by Laskey Racing
Old Oct 2, 2006 | 04:06 AM
BonB's Avatar
RHD lets see the whole car!
Old Oct 2, 2006 | 04:36 AM
B20VTI's Avatar
Default Re: Full Race Pro-am Stage 3 finally installed!! (BonB)
patients young sir , will post more pics this evening.
Old Oct 2, 2006 | 07:20 AM
4F_ Mugen CoL's Avatar
very nice
Old Oct 2, 2006 | 07:43 AM
A.S.I.M.O's Avatar
Default Re: Full Race Pro-am Stage 3 finally installed!! (CJM)
numbers please
Old Oct 2, 2006 | 07:51 AM
...me0w's Avatar
looks awesome
Old Oct 2, 2006 | 08:16 AM
sh!tsWEAK!'s Avatar
Default Re: (...me0w)
sick y0!
Old Oct 2, 2006 | 08:21 AM
Jules Winnfield's Avatar
Old Oct 2, 2006 | 08:24 AM
SFBPI504's Avatar
Default Re: Full Race Pro-am Stage 3 finally installed!! (Jules Winnfield)
Old Oct 2, 2006 | 08:27 AM
IGP EG2's Avatar
thats some good ****
W.Zero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20VTI &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>tiite setup and rhd nice. what is that gold bar off the traction bar? i see it connects to the block. is that new?
Old Oct 2, 2006 | 08:56 AM
DCnotTHEshoes's Avatar
Default Re: Full Race Pro-am Stage 3 finally installed!! (JDMroyEG5turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMroyEG5turbo &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Old Oct 2, 2006 | 12:13 PM
autox228's Avatar
Old Oct 2, 2006 | 12:53 PM
Scotty Dosent Know's Avatar
You will not be happy if that oil feed line gets into the timing belt =P
Old Oct 2, 2006 | 01:47 PM
FullRaceHonda's Avatar
Default Re: (ECKO1980)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W.Zero &raquo;</TD></TR><TR><TD CLASS="quote">tiite setup and rhd nice. what is that gold bar off the traction bar? i see it connects to the block. is that new?</TD></TR></TABLE>
that gold bar is on the full race pro-am traction bars, the gold bar is like an additional motor mount,
Old Oct 2, 2006 | 01:49 PM
American.Graffiti's Avatar
Old Oct 2, 2006 | 01:52 PM
JDM_EM1's Avatar
Default Re: (FullRaceHonda)
nice setup, should make some impressive numbers
Old Oct 2, 2006 | 02:24 PM
B20VTI's Avatar
Default Re: (JDM_EM1)
thanks peoples, the oil line is now tied back with a p-clip so cannot move from that position.
Found one problem at the moment and its ******* me off over time!! i had to trim the bumper to fit the intercooler and the piping on one side, now the ( back door) design blow off valve is hittting the bumper!!! so yet more trimming, ther be no bumper left soon!!
Ex-ITR5874
Jun 29, 2006 01:38 PM
DcWest
Dec 16, 2005 03:50 PM
POWERINTEGRA
Apr 26, 2005 02:06 PM
jbell
Aug 23, 2003 07:07 AM
Back in Black
Sep 9, 2002 06:42 PM
