Engine stalls when turn on the headlight???
Old May 1, 2002 | 09:37 PM
KekeK-18's Avatar
Default Engine stalls when turn on the headlight???
My engine will stall as soon as I turn my headlights on, Anyone know what causes this? I check all the ground and they seems fine. The car is perfectly normal when the headlights are off, even with other accessories on like radio, parking lights, wippers...etc. It only stall when I turn the Headlights on, wtf???
Old May 1, 2002 | 10:00 PM
riceboy's Avatar
Default Re: Engine stalls when turn on the headlight??? (KekeK-18)
do you have any aftermarket pulleys?
Old May 1, 2002 | 10:19 PM
aeolus's Avatar
Default Re: Engine stalls when turn on the headlight??? (riceboy)
Your iavc valve may not be working right.This valve adjusts the idle accordingly via the ELD unit.In other words,When your lights are turned on,your car needs a little more amperage to run them,so the idle goes up a little.hope this helps.
Old May 2, 2002 | 05:08 AM
badCRX's Avatar
New User
Default Re: Engine stalls when turn on the headlight??? (aeolus)
I believe there is a voltage regulator in your alternator and that may be the problem. I am having the same problem in my CRX, but I haven't fixed it yet.
Old May 2, 2002 | 11:30 AM
FLCivic's Avatar
then don't turn on the headlights, hehe
mtownek9
May 6, 2011 05:54 PM
Morlow
10
Dec 15, 2010 06:28 AM
shutta
Apr 26, 2006 09:15 AM
oblackmer
Apr 5, 2006 07:55 AM
EF_ST@TUS
Aug 9, 2005 08:31 PM
