will a 2001 gsr exhaust fit on a 95 GSR if i swap the header and cat?
Old May 1, 2002 | 08:57 PM
gsrboy01's Avatar
Default will a 2001 gsr exhaust fit on a 95 GSR if i swap the header and cat?
im going to buy a 95 GSR and i wanted to put a 2001 gsr cat back on it but i heard it will not fit. i was wondering if it would fit if i took off the header and the cat?
Old May 1, 2002 | 09:11 PM
StinkyTofu's Avatar
Default Re: will a 2001 gsr exhaust fit on a 95 GSR if i swap the header and cat? (gsrboy01)
If you swap out the 2001 header with the corresponding cat, it will bolt on perfectly fine. No problems. Since yours is obd 1, you're not going to have a plug for the secondary o2 sensor, i would get something to plug it up. or weld it shut.
PolySquared
May 24, 2006 03:21 PM
ev0luti0n
Apr 22, 2005 11:42 AM
shhh151
Jul 22, 2004 01:31 PM
AznInvasion
Jan 15, 2004 04:58 PM
