valve stem seals
Old Oct 1, 2006 | 06:06 PM
bluedlude's Avatar
Default valve stem seals
how do these come out? do they twist or just pull right out? im not going to reuse them, so if i need to use a pair of pliers so be it. its an H22 head if you were wondering.
Old Oct 1, 2006 | 06:38 PM
Revi's Avatar
Default Re: valve stem seals (bluedlude)
There is usually a special tool that pulls them from underneath, but since you are not reusing them just grip them with pliers and pull up as you twist them slightly back and forth.
Old Oct 2, 2006 | 02:10 AM
SnlpeR's Avatar
pliers work
theyre pretty hard with any tool
its ok to damage the seals since you have to replace them
i had a plier type tool with curves in the end to grip a small cylindrical thing
Old Oct 2, 2006 | 11:47 AM
prelude_h22vtec's Avatar
....god those things are a pain in the *** to get off... but yeah if youre replacing them, be sure to mess them up real nice.
Old Oct 2, 2006 | 11:52 AM
bluedlude's Avatar
Default Re: (prelude_h22vtec)
holy ****, no kidding these are hard to get off. im almost considering paying $50.00 for the snap on tool. if anyone knows of any other easy way to get these pieces of **** out let me knoow.
Old Oct 2, 2006 | 02:50 PM
bluedlude's Avatar
Default Re: (bluedlude)
I got them off, I was being a VAG!
Old Nov 12, 2006 | 09:00 AM
drumminforev's Avatar
I just ripped them out with pliers. they crushed a little, but so what they are garbage anyway if you are replacing them
Old Nov 12, 2006 | 12:36 PM
admiration's Avatar
Ah, the dreaded valve stem seal issue. I hated that.
Old Nov 12, 2006 | 05:05 PM
cidgrad130's Avatar
Default Re: (admiration)
If you are getting the head rebuilt anyway (and why wouldn't you if you have it removed???)...just have the machinist change them (they don't charge any extra). Getting the valve job is only $150-200 if you take the head to the machine shop and drop it off with the parts...well worth it.
If you are just changing the seals...then a combo of pliers and pick (looks like a dental pick but a bit beefier) usually works just fine.
Cheers!
Old Nov 22, 2006 | 12:04 AM
Default Re: (cidgrad130)
dam, i just finished mine and boy were they hard as expletive to get off with pliers. gotta pull with ALL your might with both arms with a towel wrapped around the grip of the pliers so you dont cave your palms in
....and then you fly back on your *** when they pop out unexpectedly.
Old Nov 22, 2006 | 05:35 AM
bluedlude's Avatar
Default Re: (drumminforev)
eh, if you are just going to throw them out anyway. the easiest way is.
- get a pair of thin tipped vice grips and give the stem seal a good squeeze.
- rotate the vice grips 90 degrees and give another squeeze
- now it should pull off fairly easily
or you could just get a set of valve stem seal pliers for $25.00
vinuneuro
Sep 16, 2007 07:03 AM
lude98SH
Jul 26, 2007 05:39 AM
turbotime
Nov 12, 2006 04:34 PM
RACEPAK
11
Dec 11, 2005 03:03 PM
Space Boy
May 30, 2002 12:46 AM
