d16z6 swap, 15,000 miles on brand new motor, stage 1 exedy clutch
Old Oct 1, 2006 | 05:40 PM
Simple's Avatar
Default d16z6 swap, 15,000 miles on brand new motor, stage 1 exedy clutch
Ive got a D16z6 swap from a 94 coupe. I tore down the motor for school, had to measure EVRYTHING, piston skirt diameter, cylinder bore, crank journals, rod journals, valve stem heighth, spring tension, valve guide bore, deck for warpage, head for warpage, and on and on.... you name it, i checked it.
Then i rebuilt the motor after making sure everything was good to use with new Hastings rings, and ACL bearings, and all new seals, belts and gaskets OEM honda. Water pump, and new tensioner also. Its basically a brand new motor. All parts were cleaned before assembly.
Its been in my buddies 94 DX coupe for almost a year, he drives to and from work, and to portland from salem accasionally. I bet it only has about 15,000 miles on it since the re-build.
Comes with:
D16z6 motor w/y8 intake manifold
D16z6 tranny
Axles (broken boot)
Stage 1 exedy clutch
Mounts
no linkage, no ECU, no wiring harness at this time. Looking for some currently
Currently missing distributor, but ill get it back sometime this week.
Any offers?
Modified by Simple at 6:51 PM 10/1/2006
Old Oct 1, 2006 | 09:01 PM
Spence's Avatar
Default Re: d16z6 swap, 15,000 miles on brand new motor, stage 1 exedy clutch (Simple)
y0 hit me up about this motor homie!
Old Oct 3, 2006 | 10:33 AM
#1nismo's Avatar
how much are you looking for?
Old Oct 3, 2006 | 03:26 PM
Simple's Avatar
Default Re: d16z6 swap, 15,000 miles on brand new motor, stage 1 exedy clutch (#1nismo)
... unsure, but if you're in NY like it says under your name... im definately not shipping it out there. sorry mate
Old Oct 3, 2006 | 09:21 PM
chsamia's Avatar
hey how much are u asking for the motor?
Old Oct 3, 2006 | 09:53 PM
Simple's Avatar
Default Re: d16z6 swap, 15,000 miles on brand new motor, stage 1 exedy clutch (chsamia)
make an offer.
Old Oct 4, 2006 | 06:35 AM
toeknee360*'s Avatar
hey man ill give u 500 for it and ill pick up..lmk.. ion_fx@hotmail.com if u got pictures
cloodle
28
Aug 12, 2008 09:24 AM
93civciv
Apr 13, 2005 01:51 PM
