my hood is raised..should I worry abour rain/water?
I have risers in my hood where it meets the windshield its raised about half inch or more. Should I worry about the rain and take the risers out?
The water will drain into the cowl area which has little drains in itself that go under the car. I had mine like that for a while and had no problems...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkstar1440 »</TD></TR><TR><TD CLASS="quote">Hey thanks yeah I never thought about those cars but yeah it makes sense. Thanks a lot bro.</TD></TR></TABLE>
It makes sense because they have a huge air filter only inches away from the cowl. They use it to provide air to the engine....if you want to lower engine temps it won't do much. I had my hood raised in the back and when I put it back to stock I had no temperature change (Defi temp gauge). Just FYI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">
It makes sense because they have a huge air filter only inches away from the cowl. They use it to provide air to the engine....if you want to lower engine temps it won't do much. I had my hood raised in the back and when I put it back to stock I had no temperature change (Defi temp gauge). Just FYI</TD></TR></TABLE>
Yep, worthless mod.
Yep, worthless mod.
91EXRMANUAL
Dec 16, 2004 05:27 AM
GroundZer0 336
Oct 13, 2003 09:46 AM
Does the hood vents like the cwest jdm hood, and mugen hood, leak water into the engine bay, when it
Tyson Ballou
Dec 23, 2001 08:04 PM
