rear disk brakes ?????
if i had the rear brake assembly's from a 90-93 integra what ebrake cables would i have to use to get the ebrake to work?? i have a rhd ef9 and i wanted to install the disk brakes on the back and i need the ebrake and cant figure it out. someone please help me!!!!
I don't know which chassis the EF9 is off the top of my hand but...
CRX + Rear Discs = CRX Si 90/91 E-Brake cables
Civic + Rear Discs = Civic Si / Acura Integra E-Brake Cables.
Well if your hatch is a true Si (Rear discs and all) you can use your E-brake, but if you car has drums stock for some reason, the ebrake cable is too long.
the rhd is not true it is a conversion. i have the stuff for the disk brakes just need ebrake info. if they are too long what e cables would i use
Use the DA ebrake cable... You'll be fine.
It might be a little long, you just have to route to use up the distance. It should work... I'm using the DA cable for my CRX.
If you SI already come with disc in the rear... Then just use yours.
The Disc Ebrake and Drum Ebrake cable are difference. (disc to disco and drum to drum only)
dohc_zc_build
Mar 15, 2010 01:12 PM
theinfamouskonrad
Nov 27, 2005 07:52 PM
