Spark plugs for my b16a3 with ctr camshafts.
Old Oct 1, 2006 | 09:10 AM
solerizr's Avatar
Default Spark plugs for my b16a3 with ctr camshafts.
Will NGK BKR6E-11 fit my b16a3 w/ ctr camshafts, or should i go with a different set? The book says they are supposed to be platinum, does it really matter as long as i gap the copper ones right?
Old Oct 1, 2006 | 04:01 PM
Garrett's Avatar
Default Re: Spark plugs for my b16a3 with ctr camshafts. (solerizr)
with smal bore and high CR you should used BKR7E with about 0.038-0.040" gap
Old Oct 1, 2006 | 06:24 PM
solerizr's Avatar
Default Re: Spark plugs for my b16a3 with ctr camshafts. (Garrett)
compression/bore is stock.
Old Oct 1, 2006 | 09:26 PM
inspyral's Avatar
You should be fine with either one, but the 7's are a step colder and you shouldn't really need a colder heat range with a basically stock setup.
Old Oct 1, 2006 | 11:22 PM
solerizr's Avatar
Default Re: (inspyral)
I noticed it takes longer for the engine to warm up so it hits vtec with these plugs.. is the step colder the reason?
solerizr
Oct 1, 2006 11:54 AM
P1mpSlap
Sep 25, 2003 09:41 PM
jdmtim
Feb 10, 2003 05:09 PM
