LCA bolt snapped need advice
Sup fellow HT i just had a question i snapped my bolt to the LCA near the hub and its stuck inside how can i get that out? im from the eastcoast and bolts get rusted like a motha in this area so that why it snapped as i was trying to take my LCA off
no pics but it your looking under the car at the right rear LCA it the one closet to the wheel hub 14mm bolt the head snapped on it just trying to figure easy way to take it out
ahhh the infamous one.
I have had almost every bolt in that location snap the head off on me
I cut it out, grinded down the tack'ed nut and used a bolt + nut instead.
Good luck!
I cut it out, grinded down the tack'ed nut and used a bolt + nut instead.Good luck!
^exactly
grind off the welded on nut and it should come out. use a new bolt and lock nut. did it to mine and have had zero problems.
