jdm ef climate control
Old Sep 30, 2006 | 10:48 PM
dkrex001's Avatar
Default jdm ef climate control
how hard is it to put a jdm crx/civic climate control that you can git from passwordjdm
Old Oct 1, 2006 | 03:33 AM
Solscud007's Avatar
Default Re: jdm ef climate control (dkrex001)
well I think CRX would be harder if it is the entire center console. similar to the JDM integra. the CRX center console is angled toward the driver. obviously part will not match up to a USDM dash.
Old Oct 1, 2006 | 09:59 AM
vanos_pusha's Avatar
Default Re: jdm ef climate control (Solscud007)
Honestly, it is not worth what you are going to spend...
i got one in a deal a couple of months back and took the dash out, original unit and tried to install it.....waste of time on my part! A couple of plugs connect and operate, meaning you can hear a motor running ( opening and closing something) but there is plugs that have no where to go and US plugs that are not being used.
you need a wiring diagram from the UK or Japan.
i googled it and found SOME things, but not all what I needed!
If you do get it and if you get it to work, post up!
Good luck
Old Oct 13, 2006 | 02:37 PM
RockinthEFhatch's Avatar
I remember a long time ago there was a nice thread about someone who had it almost 100% in his US crx... Does anyone remember the link? I've got most of the wiring I need I'm pretty sure. If anyone has a write-up we'd be interested.
Old Oct 13, 2006 | 02:54 PM
doublethink's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkrex001 &raquo;</TD></TR><TR><TD CLASS="quote">how hard is it to put a jdm crx/civic climate control that you can git from passwordjdm</TD></TR></TABLE>
it requires other components they do not include with that piece and the harnesses as well.
its borderline dishonest to even sell those like that to people.
The Temp control is cable driven manual in usdm crx's, (just like a bicycle brake cable) so you cant just remove the usdm panel, its not so simple. (as was said in the post above)
There is a way to do it, however if your really determined to do it using just that piece:
Buy it, install it, and then relocate you usdm cable temp control to the glovebox.
Thats the only way to keep a functional heat and a/c system and run JUST the jdm panel as password sells them, without the rest of the jdm components.
Modified by doublethink at 5:53 PM 10/14/2006
Old Oct 13, 2006 | 10:08 PM
I appreciate that thought, but I still know there's a link to a wiring diagram of someone who has done this in the past. This winter my car will be fully dismantled and I think it's time this bad boy gets installed.
Old Oct 14, 2006 | 01:46 PM
Default Re: (RockinthEFhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockinthEFhatch &raquo;</TD></TR><TR><TD CLASS="quote">I appreciate that thought, but I still know there's a link to a wiring diagram of someone who has done this in the past. This winter my car will be fully dismantled and I think it's time this bad boy gets installed.</TD></TR></TABLE>
its not a thought, its just some true info for the Original Poster before he goes out and gets something he may never be able to use.
if you already have one, and want to use it, thats cool. after you wire it up, you just relocate the usdm cable panel into the glove box.
anytime you want to change to the temp, you pop open the glovebox and make the change.
electrically, you can do everything from the jdm panel, like a/c on or off, switching zones, like vent, floor defrost etc.
did your panel come with harnesses attached?
Old Oct 15, 2006 | 12:15 PM
Default Re: (doublethink)
Yeah, I have the entire harness and all temp. sensors and everything. I just haven't had the time to put it in, and wouldn't really know where anything goes. I'm sure at least one person has done this. And I know there used to be a thread on it a long time ago.
Old Oct 15, 2006 | 12:20 PM
Zaakro's Avatar
well since you have all the sensors and stuff you should be ok and everything should work if you can figure out how to hook it up
Old Oct 15, 2006 | 07:44 PM
Default Re: (Zaakro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zaakro &raquo;</TD></TR><TR><TD CLASS="quote">everything should work if you can figure out how to hook it up</TD></TR></TABLE>
That's kind of the question I've been asking... Does anyone know how to hook it up?
Old Oct 15, 2006 | 08:14 PM
alexdog69's Avatar
schwanginpt had a working jdm climate control install in his crx, i saw it in person
very nice
but not quite sure what good it is considering how much work is involved
DarkZachiel
14
Jan 17, 2010 03:50 PM
sh3d3vilinme
Apr 10, 2009 02:41 PM
CDUFF777
Sep 29, 2006 02:29 PM
ooairewreckoo
Feb 22, 2005 06:01 PM
01h22lude
23
Sep 19, 2004 11:08 AM
