alternator belt
I just noticed recently that my belt is screaching at start up so I took a look and found that there is no adjusting locknut or adjusting bolt. I called my mechanic and said I don't need them. Is this true he said to just pry it and tighten the through bolt, but wouldn't I need to atleast have the adjusting locknut?
Ehhhh...you adjust it with the adjustment bolt like in your pic. Loosen the other bolts and tighten the belt up with that adjusting bolt and then tighten the other bolts to hold the tension.
I would, but there isn't even an adjusting bolt or locknut there and I've been driving it for about a year like that I think. Is it even possible for the belt to not fall off without those? Also when I looked at the pully above it, it seems as though the alternator belt is rubbing on it alot as it is glazed. Input...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepyH22 »</TD></TR><TR><TD CLASS="quote">loosen one 14 mm....loosen one 12mm... then get a 10 mm wrech and tighten on the adjusting BOLT! it is in you diagram just look!!!</TD></TR></TABLE>
^^im just not sure HOW to put the ***** in my butt
hah lovely angist!!
hah lovely angist!!
Did you not read what he said before you asshat? He said: <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude1888 »</TD></TR><TR><TD CLASS="quote">I would, but there isn't even an adjusting bolt or locknut there </TD></TR></TABLE> and he asked for help not a stupid answer that you gave him.
I really dont know that it is possible to drive around with that bolt not being there without the belt just working its way off. Check on a honda site to see a detailed parts diagram to see if you are just over looking it or if you really dont have it. If you dont have it, order it and then tighten like the diagram you posted discribes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CGags13 »</TD></TR><TR><TD CLASS="quote">^^im just not sure HOW to put the ***** in my butt
hah lovely angist!!</TD></TR></TABLE>
That was a douchebag thing to say as well...There was no need to even post this due to the fact that it has absolutely nothing to do with ANYTHING. I'm pretty sure you and sleepyh22 can get together and one of you will know how to stick the ***** up your butt...hell you both can take turns. You all have nothing good to offer to this site so just leave!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude1888 »</TD></TR><TR><TD CLASS="quote">I just noticed recently that my belt is screaching at start up so I took a look and found that there is no adjusting locknut or adjusting bolt. I called my mechanic and said I don't need them. Is this true he said to just pry it and tighten the through bolt, but wouldn't I need to atleast have the adjusting locknut? </TD></TR></TABLE>
man that is ghetto way of doing it, just go to a dismantling yard and buy the parts
there are several in the IE
does anyone here still have a spare alternator tensioner part laying around for sale? the inside of mine got threaded and i need a new one. can't find it in hondaautomotiveparts.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeA$$Pinoy »</TD></TR><TR><TD CLASS="quote">does anyone here still have a spare alternator tensioner part laying around for sale? the inside of mine got threaded and i need a new one. can't find it in hondaautomotiveparts.com</TD></TR></TABLE>
Under 'engine sub-cord clamp'
http://www.hondaautomotivepart...CLAMP
In the lower left of this pic:
Although I do have an extra one form swapping to a D-series alt & Explicitspeed bracket
blackcomet94
Apr 20, 2013 03:04 PM
Fo-Do Fanatic
Apr 7, 2010 03:59 AM
