**347 WHP SOHC Turbo Ninja**
Old Sep 30, 2006 | 06:27 PM
perlmeister8's Avatar
Default **347 WHP SOHC Turbo**
Well, the final build has taken place. It took most of the summer But I have gotten it to the track before it closes Here's the setup:
Block:
Benson Sleeved D16Y8 9:0 Compression
CP Pistons
Eagle Rods
ACL Bearings
Micropolished Crank
Head:
D16Y8 Head
Ported and Polished
Isky Valvesprings/Retainers
Zex 105300 Cam
Hondata Intake Manifold Gasket
Edelbrock Performer X Intake Manifold w/ port matched TB (60mm)
Transmission:
D16Y8 Transmission
OBX LSD
Action 2MS 6-puck clutch
ACT Streetlite Flywheel
OEM Axles/tranny fluid
L-Con traction Bar
Turbo Setup:
GT28RS .60a/r intake, .82 a/r exhaust
ATP Oil restrictor (.035)
RC 650 Injectors
AFI Ramhorn Manifold, 3” DP
Tial 38MM Wastegate w/ 11.8 PSI Spring
JRC 8” IC
2.5” Intercooler piping
3” exhaust turbo back
Gauges and Misc:
Defi Boost and EGT Gauges
Blox Oil pressure, oil temp, water temp gauge
Greddy Profec B Boost Controller
Blitz Turbo Timer
Greddy Type RS BOV
Koyo Radiator
GM 3-Bar Map Sensor
WedsSport SA-90 16X7 Rims w/ Nitto NT555 tires
Tokico Blue shocks w/ Progess Suspension Springs
Beaks rear sway bar
And some pics of the ride
Thanks for looking
Modified by perlmeister8 at 9:29 AM 10/2/2006
Modified by perlmeister8 at 2:24 PM 10/7/2006
Modified by perlmeister8 at 8:54 PM 11/21/2006
Old Sep 30, 2006 | 06:29 PM
freakin_eLRoD's Avatar
Default Re: **347 WHP SOHC Turbo Ninja** (perlmeister8)
this thing is nuts!!!! traction is the only thing is holding it back!!!
Old Sep 30, 2006 | 06:38 PM
95jeremie's Avatar
Default Re: **347 WHP SOHC Turbo Ninja** (freakin_eLRoD)
very nice
what psi?
what is it tuned on?
Old Sep 30, 2006 | 06:40 PM
Default Re: **347 WHP SOHC Turbo Ninja** (95jeremie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jeremie &raquo;</TD></TR><TR><TD CLASS="quote">very nice
what psi?
what is it tuned on?</TD></TR></TABLE>
18 psi, Hondata s300
Old Sep 30, 2006 | 06:47 PM
TDCTyler's Avatar
very nice
s300 rules!
Old Sep 30, 2006 | 06:49 PM
user 98292739's Avatar
whoa i have almost the exact same set up. except i dont have a manifold, and my dp is 3 inchs reduced to 2.5 cause i cant afford a 3 inch turbo back yet.
i wonder how much power i will be making. oh ya im sleeved too AEBS.
turbo is t3/t4 57 trim .63 AR
Old Sep 30, 2006 | 06:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by freakin_eLRoD &raquo;</TD></TR><TR><TD CLASS="quote">this thing is nuts!!!! traction is the only thing is holding it back!!!</TD></TR></TABLE>
Thanks for the pics sid
Old Sep 30, 2006 | 07:02 PM
tunedbylorange.com's Avatar
looks good..nice peak numbers...but why the .82 AR though? lacks in the midrange
IMO that is too big for that motor..just my .02 cents
Modified by tunedbylorange.com at 8:20 PM 9/30/2006
NastyHabitzCRX's Avatar
damn i want a VC like that
Old Sep 30, 2006 | 07:08 PM
scB20teg's Avatar
Default Re: (NastyHabitzCRX)
Nice setup, I bet that thing rips on the street. I wonder how long until you get a bigger turbo though, gt30r maybe?
Old Sep 30, 2006 | 07:18 PM
GiNuWiNe's Avatar
Default Re: (scB20teg)
The spool seems kind of slow on for some reason. Good numbers though, hopefully i can put down similar numbers.
Old Sep 30, 2006 | 07:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scB20teg &raquo;</TD></TR><TR><TD CLASS="quote">Nice setup, I bet that thing rips on the street. I wonder how long until you get a bigger turbo though, gt30r maybe?</TD></TR></TABLE>
Biggest I would go would be a gt2871R and it is in the works
Old Sep 30, 2006 | 07:24 PM
Default Re: **347 WHP SOHC Turbo Ninja** (tunedbylorange.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunedbylorange.com &raquo;</TD></TR><TR><TD CLASS="quote">looks good..nice peak numbers...but why the .82 AR though? lacks in the midrange
IMO that is too big for that motor..just my .02 cents</TD></TR></TABLE>
I wouldnt have been able to get as much power from a .63
Old Sep 30, 2006 | 08:01 PM
JDM_EM1's Avatar
great setup
Old Sep 30, 2006 | 08:05 PM
SovXietday's Avatar
Sweet!
You have restored my Y8 hope... because I'm about ready to kill mine.
Old Sep 30, 2006 | 08:19 PM
MINTGRN4DR's Avatar
purrty.. off topic but what is that color code
Old Sep 30, 2006 | 08:29 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (MINTGRN4DR)
That power curve looks like its very fun on the street. Good luck...
turbotime's Avatar
sick, props!
do you really still have traction issues with the LSD and traction bars? Im only makin 305whp but all i got is LSD [obx ftw] and it hooks up like butta!
Old Sep 30, 2006 | 08:36 PM
The_Todd's Avatar
Farts in the shower
Meh, it's alright .
Old Sep 30, 2006 | 08:50 PM
boosted94cx's Avatar
* B A N N E D *
pump?
Old Sep 30, 2006 | 09:00 PM
TIGboy's Avatar
Default Re: (boosted94cx)
very sick!!! also very clean. how quick does that 28RS spool up? good luck man! go smoke some **** now.
Old Sep 30, 2006 | 09:03 PM
H.A.R.T B18C1EG6's Avatar
nice power
Old Sep 30, 2006 | 09:11 PM
ovenwrit's Avatar
Peak torque should happen well before 5500rpm. Check for boost leaks.
Old Sep 30, 2006 | 09:16 PM
with that set up why arnt you reving past 7000?
Old Sep 30, 2006 | 09:48 PM
23honda_gal's Avatar
Default Re: (The Lobster)
call me a noob.......but Did you weld the wastegate on the turbo,or can you get a block off plate or something for it
