Hood bolt stripped out
Old Sep 30, 2006 | 03:33 PM
1989CivicSi's Avatar
Default Hood bolt stripped out
Simple question: Recently had my hood shaved/painted and I one of the bolts stripped out the hole in the hood so the hood is currently fastened with 3 bolts. For the 4th bolt, would I just re-tap the hole/run a larger bolt? What would be the best way to remedy the situation?
Thanks in advance! (Yeah, my car's in storage for a year while I'm at school )
Old Sep 30, 2006 | 06:25 PM
91civicEX's Avatar
Default Re: Hood bolt stripped out (1989CivicSi)
there are different kinds of stipped. you may be able to clean up the threads with a tap and run the same size bolt, which would be the easiest and cheapest option. technically you could move up to a bigger bolt but then you would have to drill and tap and use two sockets to take your hood off.
Old Sep 30, 2006 | 11:07 PM
rayzian's Avatar
Default Re: Hood bolt stripped out (91civicEX)
I would like to know the best method also as I stripped one of the bolts trying to do the spacer 'trick.'
I noticed now that my hood is only fastened by 3 bolts it squeeks alot (not noticeable with music though) when I go over bumps and stuff..
MGBej1503
Sep 11, 2011 12:48 PM
RenzoDaPlayboi
May 4, 2007 08:24 AM
EK9Tune
10
Feb 24, 2007 12:59 PM
Zubi
Aug 24, 2006 12:10 AM
jagged4698
Jan 9, 2005 06:03 PM
