car speakers
Try to find a speaker that is not too deep ( magent doesn't stick way out), because it will save you the trouble of cutting your stock speaker bracket. I believe stock depth is 3.5"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vegaspartyy »</TD></TR><TR><TD CLASS="quote">is there any way of knowing how deep the speaker is? is it in the dimensions or....
i really just wanna grab a pair that will gimme a clean install with no problems.</TD></TR></TABLE>
It should be listed in the dimensions as "mounting depth"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leofski »</TD></TR><TR><TD CLASS="quote">Try to find a speaker that is not too deep ( magent doesn't stick way out), because it will save you the trouble of cutting your stock speaker bracket. I believe stock depth is 3.5"</TD></TR></TABLE>
you have no idea what you are talking about.. half the aftermarket speakers out there are barely, if they even are 3.5" deep.
the stock mounting depth without having to shim the window out or make custom mdf baffles is about 1.9"
4g4drb17
11
May 16, 2004 12:12 PM
