h22 lma shim size is not right?
Old Sep 30, 2006 | 01:20 PM
esohsee's Avatar
Default h22 lma shim size is not right?
i am in the process of putting h22 spring type lmas into a b series head.
the problem is that i read the size difference is .040" but when i measured it myself with a micrometer it reads about .080" different. anyone would like to help me on this one?
Old Oct 1, 2006 | 04:49 PM
esohsee's Avatar
Default Re: h22 lma shim size is not right? (esohsee)
nobody?
Old Oct 14, 2006 | 07:17 AM
B18C Turbo's Avatar
you compared a GSR LMA to the 1999 prelude one and you came up with .080'?
Everyone says to use a .040" shim, im buying mine today.
Old Oct 15, 2006 | 04:02 PM
esohsee's Avatar
Default Re: (B18C Turbo)
yea i know everyone says .040 but when i put the washer under the prelude lma there was a visual height difference...
Old Oct 15, 2006 | 06:30 PM
B18C Turbo's Avatar
yeah I was questioning this too. Im guessing peopel use the .040" washer that sits above the tapered bore in the LMA bore to bring it up to height.
But Earl says the .040" washer that fits in the bottom of the taper in the LMA bore is good to go. So either way I guess works! $1 for the stainless washers at home depot. They are #10 and come in a plastic package with almost 15 of them. Dont even cost $1 and yes they are stainless, they drop right into the bottom of the bore.
22accordts
Sep 10, 2010 09:22 PM
Sam_J
Dec 31, 2006 12:04 PM
AznBlueBoy
Aug 12, 2005 01:32 PM
LearningNewb
Mar 23, 2005 07:08 AM
