Brake MC install?? Bench Bleed??
Old Sep 30, 2006 | 12:07 PM
Racermech's Avatar
Default Brake MC install?? Bench Bleed??
So my brake MC is dead, I was reading in my book, that I need to set the pushrod clearance with a special honda tool, vacuum gauge and a feeler tool.
Has anyone done this without al of this? Do I need to do this?
Also how do I bench bleed the unit? Do I need to?
Old Sep 30, 2006 | 12:52 PM
AllMotorDB2's Avatar
Default Re: Brake MC install?? Bench Bleed?? (Racermech)
Sit MC in a table vice, and make sure its level
fill the resivour half way up with fresh brake fluid for a sealed contaner,
using a blunt tool such as a 3/8 extention with a large socket push the MC piston in no more than 3/4 of a inch, untill piston gets stiff and will not push in more than an 1/8 in.
DO NOT push in more than an inch
How my explanation is clear
Old Sep 30, 2006 | 01:07 PM
Racermech's Avatar
Default Re: Brake MC install?? Bench Bleed?? (DAintegraGSRdb2)
After you push it in, the piston will return on its own, then repeate a few times?
ricehater60453
Honda Civic (2001 - 2005)
Jul 12, 2010 11:25 AM
n00bfasho
Jul 9, 2007 03:33 PM
nb0
Jul 8, 2007 09:14 AM
gh0st32
May 15, 2005 08:36 AM
Flux
May 22, 2003 12:50 PM
