How much is my turbo d16z6 crx worth?
I'am almost done with my crx project and have spent ~$10000 including the car, I know it is not worth anywhere near that; but, I was just wondering if you guys could give me an estimated e-appraisal on what you think my car is worth
1991 crx dx white with blue interior. Interior is in pretty good shape and exterior has some dings/chips, good paint and no rust. Car shows ~175,000mi and I bought it at ~170,000mi so everything has been done in last couple months
Here is a list of what the car has...
1995 d16z6 engine with ~100,000 miles compression checked at ~185 all cyl
1991' si tranny with about same milage. XTD stage 3 clutch and XTD light flywheel
replaced/new...
distributor
timing belt
water pump
starter
main relay
radiator hoses
axles
spark plug wires
ball joint
Full ES suspension bushings (entire car) + ES trailing arm bushing
prothane motor mount inserts
brembo D/S rotors
brodix pads, shoes, wheel cylinders
new tokico blues
neuspeed sport springs
ingalls front camber kit
rear camber kit
enkei rs-6 rims 16x7
new nexen 205/40-16 tires
alpine cd player
optima redtop
taylor wires rear battery box
omega max-e alarm with remote start/doorlocks and turbo timer
autometer boost guage
autometer air/fuel guage
rear battery kill switch
pioneer 6.5 speakers
2 amps
2 12" image dynamics subs
Perfomance...
SLS mini log manifold
SLS 2.5" downpipe
t3/t04e 50 trim
Tial 38mm wastegate (10.15psi)
Greddy RS bov
stealthmode oil lines
chipped p28 ecu
rywire dx to obd vtec harness
RC 550 cc injectors
255lph fuel pump
Full race traction bars
Full race/pwr radiator
12" electric fan
bkr7e spark plugs
still to do...
ported 62mm b16 tb
skunk2 IM
new paint job
new carpet
new seats
what do you guys think?
replaced/new...
distributor
timing belt
water pump
starter
main relay
radiator hoses
axles
spark plug wires
ball joint
brembo D/S rotors
new tokico blues
rear camber kit
alpine cd player
optima redtop
2 amps
Perfomance...
SLS 2.5" downpipe
t3/t04e 50 trim
Greddy RS bov
chipped p28 ecu
RC 550 cc injectors
255lph fuel pump
12" electric fan
bkr7e spark plugs
still to do...
ported 62mm b16 tb
skunk2 IM
new paint job
new carpet
new seats
working on getting some pics.
It is really not that important to me as I do not want to sell it now. I'am more or less just bored and was just wondering what my car is worth vs. how much I put into it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">Pix. We need them.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 civic si »</TD></TR><TR><TD CLASS="quote">hey im in stuart what color is your car..i may have seen it?</TD></TR></TABLE>
you might have, however, I have only had the car for a couple months and it has been sleeping(being worked on) more than I have drove it. it is white with painted black enkei rs6 rims. It used to have carbon fiber vinyl on the hood (put on by previous owner). The car was a crx dx auto before I bought it from a guy in tampa.
car ran a 14.2~105 w/ a 2.55 60'. This was on worn, cracked old 205/40-16 8psi untuned.
Car will run 110mph now with 10psi tuned and b16 TB+skunk2 IM
Modified by wfocrx at 3:25 PM 9/30/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 civic si »</TD></TR><TR><TD CLASS="quote">i have a d15b vtec its red gunmetal rims i just got it up an running </TD></TR></TABLE>
Did you add vtec to it yourself, or did it come that way?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ’90crxSI »</TD></TR><TR><TD CLASS="quote">
Did you add vtec to it yourself, or did it come that way? </TD></TR></TABLE>
I imagine it came that way since the d15b is a vtec engine from japan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 civic si »</TD></TR><TR><TD CLASS="quote">i bought the motor and swapped it in my car converted to obd 1 , the d15b supposedly makes more power in high rpm then the z6 , for 600 bucks i love it</TD></TR></TABLE>
thats cool, yeah the d15b is rated at like~130hp; but, you have less torque than the d16z6.
I ran a 15.7 with a horrible 60' time when I had the stock d16z6 in my rex.
wfocrx
Feb 5, 2008 07:28 PM
