GS-R Turbo setup... what do you think?
JDM GSR stock internals with skunk mani
JDM GSR tranny with OEM LSD
Garret 57 trim .60 .63 AR
AFI Ramhorn mani with 3in DP
hks bov
rc 550cc
hondata s200
im planning on boosting 10lbs and making about 275-300whp. What do you guys think? Maybe use bigger injectors?
Thanks and please dont flame
hks bov
rc 550cc
hondata s200
You wont benefit with the victorX mani until higher boost/hp levels. Grab a fuel pump though, your injectors will be more than sufficient for your hp goals. 300 hp should be very easily ubtainable @10 psi. Good luck
the bigger the wastegate the better it can hold low boost. those injectors are fine for what you want, but if you decide to go more boost you will need bigger injectors. If you have already bought them, keep them. If not, get 750 or 850cc. those will be enough to grow on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed Infliction »</TD></TR><TR><TD CLASS="quote">the bigger the wastegate the better it can hold low boost. those injectors are fine for what you want, but if you decide to go more boost you will need bigger injectors. If you have already bought them, keep them. If not, get 750 or 850cc. those will be enough to grow on.</TD></TR></TABLE>
I havnt bought the injectors yet but can I use 750cc with 10lbs or is that too much fuel?
static 50psi
I went up a little bit (55psi) before switching to larger ones, but still, i like to have no more than 80% duty cycle for safety reasons. No need to stress the **** out of them and risk smoking your engine due to an injector failure...
b18c1wes
Oct 2, 2004 05:45 AM
xtremeness101
May 1, 2004 08:37 PM
