Camshaft Experts: Your opinion on these specs.
Old Sep 30, 2006 | 06:47 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Camshaft Experts: Your opinion on these specs.
Here are the specs on a set of cams I was looking at.
Rocker Ratio
1.55 intake/exhaust
Intake
Duration: 288
Lift: .490"
Clearance: .006"
Exhaust
Duration: 266
Lift: .454"
Clearance: .008"
<u>0.50" Tappet Lift Specs</u>
Intake
Duration: 250
Lobe Lift: .316"
Opens: 25 BTC
Closes 45 ABC
Exhaust
Duration 232
Lobe Lift: .293"
Opens: 44 BBC
Closes: 8 ATC
Lobe Separations: 104
Intake Centerline: 100
Now I am not an expert here, but does the advertised duration not seem a little low? The stock advertised duration on my stock B18C1 cams is 290 & 292 vs 288 & 266. However the lift on the stock bumpsticks is .423" & .378" vs .490" & .454". Then when you look at the duration @ .050" you get 236 & 224 for the stockers vs 250 & 232. Hmmm... Can someone straighten me out here. What am I reading wrong? What are your opinions here?
Old Sep 30, 2006 | 07:07 AM
v4lu3s's Avatar
RTFM
advertised duration as far as i know can pretty much be ignored since it does not actually give you any info about when air can flow.
the lift at .050" is the usable part of the lobe.
meaning that you have a lot mroe usable duration with the aftermarket cams than the stock ones.
Old Sep 30, 2006 | 07:52 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (v4lu3s)
Cool. That makes more sense.
I don't have cam specs for aftermarket cams. Anyone know what these would be comparable too? Maybe like a BC Stage III or a Stage 1/A like Skunk/TODA/JUN etc...?
Thanks.
Old Sep 30, 2006 | 09:21 AM
DonF's Avatar
Default Re: (Mr Hammond)
Might be someones opinion of a turbo cam. Sk Stg. 2's,3's PRO 1's,2's,3's, TODA c's, vtec killers, Rocket M22x, 24x, June 3, BC 4&5 all have more duration @.050
Old Sep 30, 2006 | 09:53 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Might be someones opinion of a turbo cam. Sk Stg. 2's,3's PRO 1's,2's,3's, TODA c's, vtec killers, Rocket M22x, 24x, June 3, BC 4&5 all have more duration @.050 </TD></TR></TABLE>
Thanks DonF. See that's what I was thinking. High lift, low duration turbo cam like a Crower Stage 2T or something of that nature. I just wanted to make sure I was reading the specs correctly. What, in your opinion, would this cam be most comparable too?
Old Sep 30, 2006 | 10:36 AM
DonF's Avatar
The intake is almost a Pro1, the EX looks like a Crower Turbo cam or type "R" with more lift.
Old Sep 30, 2006 | 11:21 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (DonF)
Interesting. Thank you as always DonF for you willingness and expertise.
Old Sep 30, 2006 | 12:41 PM
DonF's Avatar
looking at the advertised duration and the .050 number I would say the initial opening and closing ramps are a little harsh.
JeffBro
Dec 18, 2012 01:41 AM
jv88_dc2
May 14, 2010 07:52 AM
westfire25
Feb 9, 2006 01:43 PM
DDD
Feb 8, 2005 08:39 AM
