speedometer cable
If you need great detai ldo not attempt yourself. But the jist of it is to remove the bezel around your dash, and all of the connections. Pull your cluter and remove the speedo cable and unhook it from the firwall and feed it down and unhook form the tranny. To install do these steps in reverse. The job is extremyl simple so these directions do not need to be expanded on.
