del sol speaker question
Old Sep 29, 2006 | 11:40 PM
crxsi8's Avatar
Default del sol speaker question
ive searched but couldn't find any good info..
Was jus wondering when del sol owners bought after market 6.5 speaker for the front did you guys have to modify anything..Ive bought some and somehow they won't fit, so just wondering what kind of modification should i do.. thanks
Old Sep 30, 2006 | 12:14 AM
ridin98civic's Avatar
Default Re: del sol speaker question (crxsi8)
buddy of mine owns a 93 del sol vtec. he didnt have any problem getting them to fit, but when he put the stock speaker covers on, the speaker would rattle against it, so he just left the covers off with plans to use a dremel to shave them down, but hes never gotten around to it.
Old Sep 30, 2006 | 12:21 AM
Socratez's Avatar
I just replaced mine with some Infinity components ... The speaker cover in the doors wouldn't accept the depth of the none factory speakers. I just removed the side and back piece (used a hack saw) leaving the round portion and mounted them back in the doors ... no rattles no troubles, sounding great ..
Soc
Old Sep 30, 2006 | 04:49 AM
Mr Hammond's Avatar
a/k/a Jomo
Most Honda's have shallow doors, so a lot of aftermarket speakers will not fit depth wise because of the larger magnet, spider etc... You can either convert to 5 1/4" as most of them will fit, or shave the stock speaker grilles to get them to clear. Some coaxial speakers will fit. Most, if not all separate components will not without some shaving.
Old Sep 30, 2006 | 05:21 AM
EG2Driver's Avatar
Default Re: del sol speaker question (Mr Hammond)
i had to cut my speaker basket to make mine fit.
Old Sep 30, 2006 | 11:46 AM
midnitesol's Avatar
Default Re: del sol speaker question (DeadEnd9009)
you could have just taken out the white plastic backing for the speaker and drilled it straight against the door. gives u plenty of room.
Old Sep 30, 2006 | 11:49 AM
dohcVTECeg2's Avatar
Default Re: del sol speaker question (midnitesol)
i bought some kenwood 6.5's and they fit perfectly. no cutting or nothing. i just bolted them on and they were good to go. try moving it around in the hole. you might be able to make it work
Old Sep 30, 2006 | 11:55 AM
honda_racing101's Avatar
http://www.dstuning.com/How_To...s.asp
This is what I plan on doing, but maybe not with type-r's. But yeah 6.5 in speakers will fit in the front, just do that, or trim up the basket and fit everything to retain the covers.
Old Sep 30, 2006 | 07:15 PM
crxsi8's Avatar
thanks..you guys are awesome..but zip tie made it the day and a lot of trimming.
Old Oct 1, 2006 | 02:26 PM
jdeemseerx's Avatar
Default Re: del sol speaker question (solbrothers)
i bet you've been dying to prove someone wrong for years... you replied to the 2nd out of 9 posts before yours and had nothing to contribute to the topic, take your del sol vtec knowledge and shove it. GL to the OP Infinity for TMFW
Old Oct 4, 2006 | 09:46 PM
sorry man i must have missed the 4 key, let me bow down before your godlike knowledge of hondas and then tell you to shut the expletive up, quit trying to correct people and reply to the topic at hand. fitting the speakers in the del sol!
Old Oct 6, 2006 | 08:47 PM
Bob Dole!'s Avatar
yea i put some memphis's in my doors and had to cut out the back of the speaker bracket but just make sure you have 6.5 inch speakers and not the oversized or 6.75 then you'll probably have to cut and mdf ring and mount them in that way, is what we did with my buddies s2k
Old Feb 4, 2010 | 04:23 AM
nobaker's Avatar
What size are the rear speakers =(
Old May 30, 2010 | 03:29 PM
Solebrity's Avatar
I know this an old thread. Just did the diy dstuning. My problem is the speaker falls out backward. So what keeps it it place.
Carter Goff
Feb 23, 2019 04:00 PM
94DS
Audio / Security / Video
May 28, 2011 05:57 PM
s2000onvolks
10
Feb 1, 2008 08:33 AM
matt56
Jan 13, 2007 06:43 AM
RosebloodSol
Dec 1, 2001 10:37 AM
