Working on some body work..
Old Sep 29, 2006 | 10:29 PM
02 eM2's Avatar
Default Working on some body work..
sorry if i'm riiced.
couple days ago
i was at a gas station & got a hit & run when i went inside to pay cash.
& i didnt set my alarm on but its a long story....
all i can say is.. dont pay inside!
but here is the damage before & STILL WORKING ON IT!
hopefully the car will be ready. cuz i gatta go to work by 12pm.
here the pixs
before
it is a custom paint. but i just used the stock paint to respray it & it kinda comes out ok but here is 1 pix where i did some body work where u can see where it need's to be gloss.
but tell me what u think?
Old Sep 29, 2006 | 10:37 PM
MidShipCivic's Avatar
Great but your not done yet you need some 05 tail lights.
Old Sep 29, 2006 | 10:41 PM
02 eM2's Avatar
Old Sep 29, 2006 | 10:42 PM
tnbigdawg's Avatar
Default Re: Working on some body work.. (02 eM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 eM2 &raquo;</TD></TR><TR><TD CLASS="quote">
The body work on the trunk:
You do know water and bare metal don't mix well together right? It looks like you hosed it off with water. Body filler (or Bondo as it has become known by) is porous and absorbs water. So by the time you add your topcoats, the bond between the filler and metal becomes compromised as rust starts to occur.
In other words after you paint it, it will look good at first but then a "bubble" will start to appear as the filler lifts away from the metal.
You're supposed to clean the area with a mild solvent (I use Dupont's Final Clean) and then use an EPOXY or Etching primer. Then layer on a sandable Primer Surfacer(usually Urethane Primer aka 2K primer surfacer). Wetsand, and your're ready for paint depending on how well you did the bodywork.
Goodluck.
Old Sep 29, 2006 | 10:48 PM
02 eM2's Avatar
i didnt mix the bondo with water AT ALL!
i just rinse after words. thats all.
i dryed it up with a shammy. i was in a hurry for pixs
Old Sep 29, 2006 | 10:51 PM
tnbigdawg's Avatar
Default Re: (02 eM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 eM2 &raquo;</TD></TR><TR><TD CLASS="quote">i didnt mix the bondo with water AT ALL!
i just rinse after words. thats all.</TD></TR></TABLE>
read my post again. I edited like 20 times.
Yeah you want to avoid water at all times! Until there is a corrosion resistant primer(i.e EPOXY primer), THEN you can use water all you want.
Water comes into the picture when you are wetsanding 2K primer or other topcoats.
On another note, you don't want to wetsand a Polyester primer because those are porous too UNLESS you laid down an EPOXY primer first.
Modified by tnbigdawg at 12:03 AM 9/30/2006
Old Sep 29, 2006 | 10:53 PM
02 eM2's Avatar
i'll be in good hands. good lookin on the info.
Old Sep 30, 2006 | 04:18 AM
toyomatt84's Avatar
Sanji
Hate to say it, but I know from the my first encounter with Bondo, if you put water on it, you should expect to see rust. I don't care how good the hands are, you just poured water onto a sponge, and are going to paint over it. The surface will look dry, but there will be some unevaporated moisture that, no matter what you think, will still be in the Bondo.
Old Sep 30, 2006 | 07:42 AM
02 eM2's Avatar
no matter what theres fog all on the windows & body. either way theres still water on it. i just took a peak, its lookin good!
& gatta go to the store to pick up a few things for the job.
here is another pix tooken this morning.
Old Sep 30, 2006 | 07:56 AM
hurleyint's Avatar
dont expletive it up
ive seen the outcome
Old Sep 30, 2006 | 08:37 AM
02 eM2's Avatar
i keep on posting some pixs
in the mean time.. time to finished the job.
Old Oct 3, 2006 | 01:51 AM
tnbigdawg's Avatar
Default Re: (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">Hate to say it, but I know from the my first encounter with Bondo, if you put water on it, you should expect to see rust. I don't care how good the hands are, you just poured water onto a sponge, and are going to paint over it. The surface will look dry, but there will be some unevaporated moisture that, no matter what you think, will still be in the Bondo.</TD></TR></TABLE>
I'm not trying to give you a hard time, it's just that I have experience in this field and trying to share the knowledge.
On another note....The body filler should not overlap paint. The only filler that sticks best to paint would be a 2 part icing which is a polyester finishing filler(not really needed). You might get away with it for now, but it might lift on you. I know you're still gonna work on it but just a heads up, the filler should be feathered out more. You don't want hard lines ever on anything.
When you prime, let it fan out as a transition. Don't primer it over a tape line or else you'll create a line that will appear when you paint even when you've think you sanded it out.
Oh yeah, do keep posting pics and update on your progress
Old Oct 3, 2006 | 02:12 AM
SPITVENOM67's Avatar
Default Re: (MidShipCivic)
uhhh
Old Oct 3, 2006 | 05:20 AM
fventura03's Avatar
i think you've put too much on, and its too thick. keep us updated
Old Oct 8, 2006 | 01:18 PM
02 eM2's Avatar
here out it came out last weekend.
there was alot of rain.
i couldnt spray it, cuz it wouldnt came out right.
so i decided to do it.
& i did! & hoping i would get some time today while there's sunlight to respray it again!
yesterday...
freeway, traffic, bumper to bumper, people cutting me off, had to tailgate,
40mph, saw a pot hole, was in the fast lane, going to livermore, far right lane & the one next to it, was on road construction, ONLY 2 lanes open, saw a pot hole, I swerve'd BUT NOT ENOUGH!, cought my left rear wheel, SMACK!, took the next exit, saw it & it was BADD NEWS!
this one is going to be harder....
~....teary....~
any idea's?
Old Oct 8, 2006 | 01:22 PM
Jules Winnfield's Avatar
sorry about your luck man
Old Oct 8, 2006 | 01:37 PM
SiB16A's Avatar
Default Re: (Jules Winnfield)
Old Oct 8, 2006 | 01:44 PM
donkiman's Avatar
throw the Stanley head and tail lights back on and it'll look a whoooole lot better
Old Oct 8, 2006 | 02:05 PM
ekcivic9's Avatar
the jdm gods are coming after you
/sarcasm
Old Oct 8, 2006 | 03:29 PM
BIGBLOCKEK's Avatar
Botched thread poll
Default Re: (ekcivic9)
holy crap, im going to keep my eyes peeled if im ever on those freeways, but i always cut through the canyon/hills on 84 anyways.
580/205 sucks ***.
sorry about the bad luck
Old Oct 8, 2006 | 03:34 PM
FalkenSiR's Avatar
Old Oct 8, 2006 | 03:42 PM
nightrider's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jules Winnfield &raquo;</TD></TR><TR><TD CLASS="quote">sorry about your luck man </TD></TR></TABLE>
i sure as hell don't feel bad. your exterior mods are hideous and obviously not very good for daily driving.
Old Oct 8, 2006 | 07:07 PM
EM1SON's Avatar
Default Re: (nightrider)
just find your old tails and get them on.
Old Oct 8, 2006 | 08:59 PM
02 eM2's Avatar
Default Re: (lesturrr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lesturrr &raquo;</TD></TR><TR><TD CLASS="quote">just find your old tails and get them on.</TD></TR></TABLE>
problem!
<U>MOLDING</U>.
the one on top is 45series
the bottom one is 35series (I MISS THEM!)
Old Oct 8, 2006 | 11:32 PM
tnbigdawg's Avatar
Looks like your kit is molded on? That sucks man. Now you gotta paint the whole rear section all the way to the front fenders just for a bumper and sideskirt repair.
A bodyshop can get away with just spot repair/blend of the basecoat, but the clear should be applied to all connecting panels. In other words don't let them do a blend of the clear coat.
Goodluck.
