d16z6 and b16 map and tps interchangable?
Old Sep 29, 2006 | 10:24 PM
wfocrx's Avatar
Default d16z6 and b16 map and tps interchangable?
I have a d16z6 engine in my crx. I am looking to upgrade the tb and Iam thinking about gettting a ported b16 tb. Will the tps and map from my d16 tb swap onto the b16 tb?
Old Sep 30, 2006 | 06:43 AM
jackinthetrunk's Avatar
Default Re: d16z6 and b16 map and tps interchangable? (wfocrx)
need more info, is it obd1?
Old Sep 30, 2006 | 07:16 AM
89 civic si's Avatar
Default Re: d16z6 and b16 map and tps interchangable? (jackinthetrunk)
i dont think the d16z6 has the map on the throttle body..i know my d15b vtec does but i know some b16s do have one on the throttle body which in your case would just plug in to the throttle body rather then the firewall
Old Sep 30, 2006 | 07:57 AM
wfocrx's Avatar
acutally, the d16z6 does have the map on the throttle body and is obd1 so I would image the throttle body Iam using is both obd1 and has a map on the throttle body like the obd1 b16 throttle body I'am buying.
I was just asking if the obd1 b series TB would work with my obd1 d series setup?
Old Sep 30, 2006 | 07:58 AM
wfocrx's Avatar
Default Re: (wfocrx)
p.s it says "obd1" in my sig.
Old Sep 30, 2006 | 07:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wfocrx &raquo;</TD></TR><TR><TD CLASS="quote">p.s it says "obd1" in my sig.</TD></TR></TABLE>
hahah oops.
.Grimace
May 25, 2007 01:48 PM
JUN.
Apr 24, 2007 06:55 AM
boostedcivicsir
Apr 23, 2007 06:30 AM
R_type
May 26, 2005 10:21 PM
CandyRedHatch
Apr 21, 2004 12:25 PM
