is having a smaller crank pulley bad for anything?
Old Sep 29, 2006 | 10:06 PM
vladd's Avatar
Default is having a smaller crank pulley bad for anything?
I have a 99 gsr. my crank pulley was a little bent and wobbled a bit, so i bought a used crank pulley from someone on here, who claimed it was off a gsr. turns out its a little smaller than my original one. the one on the left in the pic is the original one. will it do anything bad to the alternator or ac pump?
Old Sep 29, 2006 | 10:21 PM
gsr dood's Avatar
Default Re: is having a smaller crank pulley bad for anything? (civicdxtyper)
make sure u get the rite size belt....
Old Sep 29, 2006 | 10:29 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper &raquo;</TD></TR><TR><TD CLASS="quote">I have a 99 gsr. my crank pulley was a little bent and wobbled a bit, so i bought a used crank pulley from someone on here, who claimed it was off a gsr. turns out its a little smaller than my original one. the one on the left in the pic is the original one. will it do anything bad to the alternator or ac pump?</TD></TR></TABLE>
Not at all. I had the same problem and ended up with an ITR pulley that is a little smaller and it works just fine. I had to get a smaller alternator belt, though.
Old Sep 29, 2006 | 10:36 PM
vladd's Avatar
Default Re: is having a smaller crank pulley bad for anything? (gsr dood)
it looks like i'll be able to use the original belts. i can move the alternator back far away to be able to still tighten the belt. same for a/c. the alternator and ac compressor will be spinning a little faster, i'm just making sure that won't be a big deal.
tag0617
Apr 12, 2009 06:13 PM
halocore
Aug 11, 2008 07:06 PM
See Are X
Jul 1, 2003 07:47 AM
NateTEG95
May 30, 2003 09:24 PM
fe519
Feb 16, 2003 03:41 PM
