Will BC spec 4 cams run like shiz without headwork?
Old Sep 29, 2006 | 04:14 PM
ZenkaiRacer's Avatar
Default Will BC spec 4 cams run like shiz without headwork?
I want some cams along the lines of the Buddy Club spec IV's. But headwork and higher compression are the last things on my list to do. I will have a JDM gsr engine if that helps compression wise.
Will I be ok on cams this crazy until I get the headwork and compression up?
Old Sep 29, 2006 | 10:27 PM
Combustion Contraption's Avatar
It wont run like ***, but you will not be utilizing the camshafts full potential.
As a sidenote: unless you peice together a build around a particular set of camshafts (int. runner length/diam, exh. runner length/dia, cylinder head flow, port size, compression, etc.) you are never really using ANY cams full potential.
Old Sep 29, 2006 | 11:08 PM
mekanism's Avatar
Default Re: Will BC spec 4 cams run like shiz without headwork? (ZenkaiRacer)
Why dont you just save up for the headwork and bottom end work. You will save yourself a trip to the tuner and save some cash too. Trust me you wont regret it. I have the BC4's in my gsr with ported head and 11.8:1 compression and it hauls *****. Worth every penny!
bxsi
Apr 2, 2004 05:42 AM
jdmcx
Dec 21, 2003 06:34 AM
PyR01-0347
Sep 21, 2003 04:07 AM
VTEC-DA
Mar 7, 2003 12:14 PM
