wheel stud
Old Sep 29, 2006 | 04:03 PM
JJ's civic's Avatar
Default wheel stud
i need to change a stud or two. my question is do i have to take the hub off. i've try before to take my hub off and it was unsussesful. is there any other way.
Old Sep 29, 2006 | 04:08 PM
89 civic si's Avatar
Default Re: wheel stud (joeny12985)
you have to take the rotor off its really easy..then just pull the stud through..get one or two washer.then thread the lug nut on..you must have an impact gun to do this as i have never seen anyone do it any other way there might be another way..eventually as you tighten it down enough it will pull through..good luck
Old Sep 29, 2006 | 04:10 PM
JJ's civic's Avatar
Default Re: wheel stud (89 civic si)
yea i know i can do it with out power tools. i forgot to mention it's in the rear
Old Sep 29, 2006 | 04:16 PM
you arent going to have to do anything you may have to move the brake shoe buts thats about it. its easy when you get in there and do it
Old Sep 29, 2006 | 05:01 PM
HONDACURA-DB8's Avatar
Remove the hub cap by using a chisel type like tool & a hammer. Try to wedge it between the hub and the cap so it will pop out. Once that is done remove 32mm spindle nut and then the hub will silde right out.
hightechredneck
Apr 6, 2013 03:18 PM
airikkCRX
Jan 16, 2010 04:31 PM
ewoo
Feb 24, 2009 04:23 PM
simonEp3
Sep 3, 2008 04:49 PM
typeeg
Jul 20, 2004 05:21 PM
