DART GSR Head Flowrate.
Has anyone seen or done a flow test on this? Im really curious seeing it has 34mm Valves and CNC ported right from Dart. I wonder if this head can hang with some of the big guns in porting.
Searched with no results.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darkane »</TD></TR><TR><TD CLASS="quote">Cool; Id love to see that.
x2
</TD></TR></TABLE>x2
They are expensive, but you get what you pay for. If the head flows as good as the flow sheet says that it will, then it should haul a##. I know that DART works constantly with wetflow flowbenches, so if it flows that good on a standard bench, then you know that they didn't just go in there and hog the ports out, because if they did just hog out the ports, then it would perform horribly on a wetflow bench, and I don't think that DART would mass produce anything that performed horribly on a wetflow bench. Which means that it should make killer power.
I wouldn't think that they would just lie about it either, because that would set a bad impression on their company's name.
Been busy, but here's the numbers when DART released the head back in 2004. And if you've never seen a DART head, I have some pictures of the bowls and such too...
All I'll say is that I have done ALOT of testing on cyl head , recently 4 gsr heads . I will put my neck out here and say that putting a 34mm valve on a stock valve seat is Guaranteed to lose power with a stock bore chamber. Your better off running a stocker over a 34mm. You have to put bigger seats to accomdate the larger sized valve job to support 320 cfm.
I'll even to go furter to show one of my current spare race heads for the project 300 motor. This piece as this was a fixed up head that was fully ported 5 years ago.. 5 years ago it flowed 280 and now alot better
yeah this is exactly where I wanted this thread to go. Good ****.
So on paper Dart seems amazing but real world experience Prevails.
Edit: I just realized Dart makes the bore 84.5mm aswell. Any thoughts on that Tbone?
So on paper Dart seems amazing but real world experience Prevails.Edit: I just realized Dart makes the bore 84.5mm aswell. Any thoughts on that Tbone?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone »</TD></TR><TR><TD CLASS="quote">
i see someone has been toying with brad's baby
how close are you to finished on that project?
edit: wait thats not at rlz is it?? did they paint or move it or something?? or is that somewhere else?
</TD></TR></TABLE>i see someone has been toying with brad's baby
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever »</TD></TR><TR><TD CLASS="quote">
edit: wait thats not at rlz is it?? did they paint or move it or something?? or is that somewhere else?</TD></TR></TABLE>
New walls and paint
New walls and paint
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAX_CFM »</TD></TR><TR><TD CLASS="quote">New walls and paint </TD></TR></TABLE>
oooh very nice
oooh very nice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darkane »</TD></TR><TR><TD CLASS="quote">yeah this is exactly where I wanted this thread to go. Good ****.
Edit: I just realized Dart makes the bore 84.5mm aswell. Any thoughts on that Tbone?</TD></TR></TABLE>
So on paper Dart seems amazing but real world experience Prevails.Edit: I just realized Dart makes the bore 84.5mm aswell. Any thoughts on that Tbone?</TD></TR></TABLE>
So does DART make a head with a valve that is more accomodating for "real world" motors?
Anytime I see a head flow at 300 or more, I give the porter a
