Need help from guys with an HF Crx please!!! Can u check something for me?
* B A N N E D *
Can you tell me the exact colors of the wires for these following sensors
Coolant temp Sensor (2 Wired sensor on the side of the head)
Needle Temp sensor (Single sensor on side of the head to feed the gauge needle)
O2 Sensor wire (the single one)
IAT Sensor Wire (goes on intake manifold, is a 2 wired sensor)
Oil pressure sending wire (single wire)
If i can find these wires thats all i need to get my car running!! So please help me out.. Thanks in advance!!!
Coolant temp Sensor (2 Wired sensor on the side of the head) - red/white & green/white
Needle Temp sensor (Single sensor on side of the head to feed the gauge needle) - yellow/green
O2 Sensor wire (the single one) - white
IAT Sensor Wire (goes on intake manifold, is a 2 wired sensor) - red/yellow & green/white
Oil pressure sending wire (single wire) - yellow/red
foress_89
Jan 15, 2008 03:58 PM
