FS/FT: Leftover Honda parts <NYC/LI>
GSR BLOCK mount----40
LS Block Mount------40
B-series AC bracket---20
B-series Driver TQ mount--20
B18a Intake Manifold---40
b18a Head-----------60
New engine stand-----50
obd1 auto Integra Starter-----20
LS flywheel----------20
Ls clutch pplate-------40
LS clutch disc---------20
GSR brake calipers-----60
95 Integra OEM Front rotors---40
-B-series Hydro ACT 6 pluk unspran disc..60
-GSR crank...bo
-EG/DC driver side body mount..bo
-B-series Crank oil seal cover..b0
-GSR cam caps
-93 Integra clutch cable tranny cable
-LS crank main caps w/bolts
-GSr water pump
-GSr oil pump
-GSR stock clutch setup Hydro
-LS oil pan MINT
-D-series oil pan
-EG civic OBX rear exhaust-60
-NEW Tsudo N1 exhaust--80
-91 Integra Cluster
-90 Ls head
-Ls cams w/ gears
Ls head studs
D-series obd 1 ALT
b-series alt brakets
Skunk2 IM B16/ITR head>>>>>>>180
FAZE tach>>>>>>>>>>>&g t;>>>>>>>>bo
90-91 Integra Turn lights>>>>>>>>>>> >10
90-93 Integra rear sway bar>>>>>>>>>>>> ;20
lock with key>>>>>>>>>>>> ;>>>>BO
Intake mani support>>>>>>>>>>> ;>>>>>BO
Integra GSR brake mastercyc>>>>>>>>>>& gt;>>>>40
obd-0 b-series starter auto>>>>>>>>>>>&g t;>>>>>>>>>20
LS fuel rail>>>>>>>>>>>&g t;>>>>>>>>>>>> >>>>>>20
OBD-0 JDM b16a injecters>>>>>>>>>>& gt;>>>>>>>>>60
90 Integra cluster 198miles, w/ SOME FUEL>>>>>>>20
2000 civic dx Gray cloth front seats, NO RAILS you have to re-use ur own..60
-2000 rear Integra GSR cloth seats black and blue 60
rear hatch GLASS fits all 94-01 Integra Hatchs...80
-GSR crank...bo
-GSR cam caps
-GSr water pump
-GSr oil pump
-LS oil pan MINT
-D-series oil pan
-91 Integra Cluster
-90 Ls head
-Ls cams w/ gears
Ls head studs
D-series obd 1 ALT
