14x7 Team Dynamics Pro Race 1.2 with 225/40/14 Toyo T1-R
selling a set of mounted wheels and tires off of my civic.
cost me almost $900 new
Selling for $550. need to buy new rims and R compounds for my autocross car. my loss is your GAIN, and these things KICK A** in the rain.
Rims: 14x7 Team Dynamics Pro Race 1.2
Color: Anthracite
Bolt Pattern: 4x100
Offset: 38mm offset (i'll check, they may be 35mm offset)
Weight: Just under 12 lbs each
only used on daily driver for about 4-5 months.
These go for about $130 each new and are sometimes a bit hard to get as they come from England.
Tires: Toyo T1R
Outer Diameter: 21.1"
section Width: 9.2"
treadwear rating: 280
Weight: 16 lbs
TreadLife Left: 85-90%
These tires are an inch wider section with then a 205/50/15 Azenis. also they are 5.2 lbs lighter.
this combo weighs about 28 lbs total. you'd have to buy a rim lighther then 7 lbs if you wanted to get the same weight with the azenis.
a 205/50/15 Azenis is 23.1" outer diameter. these 14's will greatly increase your gearing on your car. great for someone running in SCCA STS class. especially if your gearing sucks. plus it's 225mm wide so it will help you get about 1" more rubber on the pavement over a 205mm tire.
you can get your car SUPER LOW with these too,as they are 2" shorter then a 205/50/15.
They are on my car now but will be taking off in the next few days unless somebody needs them ASAP
Modified by hybridmoments at 3:49 PM 9/29/2006
Color: Anthracite
Bolt Pattern: 4x100
Tires: Toyo T1R
section Width: 9.2"
Weight: 16 lbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by It’s*BOLO!! »</TD></TR><TR><TD CLASS="quote">wow that tire size is crazy BUMP </TD></TR></TABLE>
LOL if you say so bolo.....I can vouch for the freshness!
pending sale tonight!!
yah. tough to find good sized 14" wheels. i definitely recommend these. much nicer build quality and finish then a Rota, Konig, etc. and they are known to be tough as lots of Spec Miata guys ran/run? these wheels.
And they are made in Jolly Ole' England!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmoments »</TD></TR><TR><TD CLASS="quote">Thanks for the Vouch ANDY
i will have to make you some more HIM decals now!
Stephen</TD></TR></TABLE>
LMAO, no prb bro..if kayanimation is getting the wheels, he's a nice guy to deal with as well
STN_Pat
Oct 17, 2011 06:59 AM
brasilracing
Sep 13, 2002 12:02 PM
Tanner
Jul 4, 2001 11:28 PM
