Crankshaft oil seal leak???
Old Sep 29, 2006 | 01:46 PM
imtrill's Avatar
Default Crankshaft oil seal leak???
I have a oil leak coming from the crankshaft pulley. Its a slow leak and only leaks a drop of oil every couple of hours. Usually after I have driven it. It looks like it could be the oil seal. When changing the oil seal do I need a seal remover tool or does it just come off and when I install a new one do I need a tool to install it? Could anything else be causing this problem such as the oil pump?
Old Sep 29, 2006 | 03:35 PM
NJIN BUILDR's Avatar
Default Re: Crankshaft oil seal leak??? (imtrill)
The front crank seal is in the oil pump.You should be able to pop it out with a screw driver.It will take some care to get the new one in correctly.You can also remove the pan and then the pump.It will be alot easier the change the seal on the bench.
wtsapexipowerfc
11
May 28, 2011 04:47 AM
kulo
Jan 18, 2011 12:14 PM
pjr710
Feb 6, 2009 10:23 AM
ty_racer
Apr 1, 2005 01:49 PM
deepnite
Oct 9, 2002 01:46 PM
