Civic Engine Swap
I have an 89 Civic si with stock D16. For classing purposes, I need to swap down to a D15B2 engine. Both are PGM-FI. Will the si harness match up? Will I need to swap the ECU as well?
Also, would an si 5 spd. 4.25 ring and pinion fit into a 4 spd. diff?
Thanks.
Thanks.
ive never heard of anyone doing this before. youd be better off getting a dx or std, they are lighter and already have the dpfi.
you will have to modify the harness and swap the ecu, not sure about the tranny though.
Thanks to all who responded. I think I have a handle on what I need to do.
FYI, the "downgrade" is due to a class (that I want to race in) restriction that doesn't allow the si engine.
