Flywheel Bolts: Removal
So finally after getting all the bolts off of the tranny and other things, i finally wiggle the tranny out! I was able to take off the pressure plate and clutch disc, but now I am having a flywheel removal problem. I got one bolt free that is holding the flywheel but the rest won't come off. Coming off isn't really the problem, the problem is the flywheel keeps spinning. How do i keep it from doing that or is there another way to remove the bolts?
Thanks in advance!
Thanks in advance!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivinVtec »</TD></TR><TR><TD CLASS="quote">theres a tool that hold the flywheel. It has a handle with this hook thing. while your pullin on the FW your push the nuts free. you follow??</TD></TR></TABLE>happen to know wut the tool is called?
i have air tools but those suckers are on there tight. or my gun is just to weak. i was only able to remove one bolt with the gun...do they make 17mm star impact sockets?
you could, I dont recomend it, use a very heavy flathead screwdriver in one of the FW teeth to brace the FW against one of pins that hold the tranny in place..... it takes 2 people, and you can scratch the hell out of your flywheel if you are not carefull...... but it can work if you dont have the guid tool or a good impact hammer.
You are suppose to remove those bolts in a crisscross pattern one step at a time. You will cause damage to the crank and/or flywheel if you dont. You could also hold the crank still throught the crank pully. Have some one hold the crank puuly with 19mm socket and a breaker bar. The crankpully is on there much tighter than those flywheel bolts so the bolts should break loose instead of the crank pully. Just be sure to tightend that crankpully back up to 181ftbls.
yup do that. I also sprayyed wd40 on the bolts overnight and let them sit, came off like cake in the morning with an impact gun. hold it from other side by hte crank pulley .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4_MADMAN »</TD></TR><TR><TD CLASS="quote">any tips for removing flexplate bolts? No teeth to jam screwdriver in.</TD></TR></TABLE>
Have access to the crank bolt on the other end?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest »</TD></TR><TR><TD CLASS="quote">
Nada. Not much left of the shortblock, in fact the crank is out once these bolts are free.
</TD></TR></TABLE>Nada. Not much left of the shortblock, in fact the crank is out once these bolts are free.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest »</TD></TR><TR><TD CLASS="quote">Even with everything stripped off the timing belt side, you can put the crank pulley bolt back in and use that to keep the crank from turning.
I dont have the bolt. It wasnt there when I bought the block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude »</TD></TR><TR><TD CLASS="quote">Your gonna need one soon anyhow - just go buy one.</TD></TR></TABLE>
No, I dont. it was purchased for certain parts that I needed and the rest is being parted out.
F it Ill figure something out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 »</TD></TR><TR><TD CLASS="quote">so instead of using the right tools / parts that can get this done in like 5 minutes. you choose to jimmy rig it and take much longer.
ok, suit yourself</TD></TR></TABLE>
So you want me to waste money on a bolt I have absolutely no use for?
No other tool was mentioned for a flexplate, there are no teeth so a flywheel tool wont work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude »</TD></TR><TR><TD CLASS="quote">I see - I would say there has to be a way to use one of the holes in the plate in the same manner as a tooth on a flywheel.
Or get a bigg *** impact and a good compressor.
Sorry I can't be more help.</TD></TR></TABLE>
There are LOTS of holes in the flex plate, maybe I can find a bolt to put through it to lockit down. ****** automatics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4_MADMAN »</TD></TR><TR><TD CLASS="quote">This was the only peice I needed from the whole shortblock-
What is it?
</TD></TR></TABLE>What is it?
What is it?
Crankshaft timing gear. **** didnt want come off either, had to persuade it a bit.
What is it?
</TD></TR></TABLE>Crankshaft timing gear. **** didnt want come off either, had to persuade it a bit.
