my fan isnt going on!!!
Old Sep 29, 2006 | 11:46 AM
-Championship-'s Avatar
Default my fan isnt going on!!!
i recently changed my radiator and my fan wnot go on, the temp was going past the half way point, so i wired it directly to the battery for a temporary use only, i made shure the harness is plugged but the fan still wont turn on...could it be a fuse?
Old Sep 29, 2006 | 12:16 PM
BLKGSR24's Avatar
Default Re: my fan isnt going on!!! (CW_98gsr)
Try jumping the connector that plugs into the T-stat housing with a paperclip. I think the car has to be on but the engine doesn't have to be running, but anyways if the fans don't kick on when you jump the plug then there's something wrong with the fans like a bad relay or fuse. If they do kick on then you problem most likey is the ECT switch.
Old Sep 29, 2006 | 12:17 PM
BLKGSR24's Avatar
Oh I just realized you changed the radiator... Did you bleed the system after you filled it up with coolant? Air in the cooling system will cause your car to heat up real quick.
Old Sep 29, 2006 | 12:42 PM
Default Re: my fan isnt going on!!! (BLKGSR24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKGSR24 &raquo;</TD></TR><TR><TD CLASS="quote">Try jumping the connector that plugs into the T-stat housing with a paperclip. I think the car has to be on but the engine doesn't have to be running, but anyways if the fans don't kick on when you jump the plug then there's something wrong with the fans like a bad relay or fuse. If they do kick on then you problem most likey is the ECT switch.</TD></TR></TABLE>
uummmm yeeeeeeeah...dont know what the hell is a ect switch, and t-stat but yeah...i think i already bled the radiator...but fan still wont start, the stock fan didnt go on, and neither did this one, but nothing wrong with the fan, just the harness
Old Sep 29, 2006 | 12:45 PM
The Destroyer's Avatar
Its on the thermostat housing.
Old Sep 29, 2006 | 12:46 PM
BLKGSR24's Avatar
Old Sep 29, 2006 | 03:21 PM
Riake's Avatar
Check the underhood fuses, they are right next to the battery. They are designated very clearly on which is which.
BB409
Apr 23, 2009 03:45 PM
esean93
11
Jul 29, 2008 05:33 PM
aznlaoboi315
Mar 13, 2008 02:35 PM
Siegfried
Jan 6, 2007 09:00 AM
screen_name
23
Jul 22, 2005 06:48 PM
