Vented the Valve cover
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drintegra »</TD></TR><TR><TD CLASS="quote">I want to do this also where did you get the bungs and fittings? How much $$=??</TD></TR></TABLE>
fittings alone was about 150
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Riake »</TD></TR><TR><TD CLASS="quote">Is the valve cover aluminum or steel?</TD></TR></TABLE>
aluminum
aluminum
Don't know what fittings those are.. But I bought 2 90* fittings from summit for 30 dollars and about 15 dollars for 2 aluminum weld in bungs.
Don't know yours could be red anodized gold fittings....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCtor Boost »</TD></TR><TR><TD CLASS="quote">Don't know what fittings those are.. But I bought 2 90* fittings from summit for 30 dollars and about 15 dollars for 2 aluminum weld in bungs.
For real....my two -12 an 90 degree fittings were $24 each.
Weld on alum -12 male fittings were $8.95 each.
I got all from bakerprecision.com
</TD></TR></TABLE>For real....my two -12 an 90 degree fittings were $24 each.
well i bought 4 90* fittings at 30 bucks each, so thats 120 plus the weld on bungs which was 15 bucks and 2 female to male for the catch can at 20 bucks.
</TD></TR></TABLE> well i bought 4 90* fittings at 30 bucks each, so thats 120 plus the weld on bungs which was 15 bucks and 2 female to male for the catch can at 20 bucks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dollar_bill »</TD></TR><TR><TD CLASS="quote">Post pics of the inside of the valve cover.</TD></TR></TABLE>
you wont see anything, the bungs are welded behind a baffle in the valvecover.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedJeff »</TD></TR><TR><TD CLASS="quote">you wont see anything, the bungs are welded behind a baffle in the valvecover.</TD></TR></TABLE>
Yes, and if you plan on doing this, make sure you weld them on the front and not the back. There is no baffle on the back, and you will have a full catch can in the blink of an eye.
Mine are in the front and back and the can for the backdoesnt fill fast at all.
