amp installation... plz help
Old Sep 29, 2006 | 06:36 AM
98coupeex's Avatar
Default amp installation... plz help
hey i'm a little new to amp installation and im trying to run a power cable from my sub box in my trunk, the to battery. One problem i need to get through my firewall and all of the grommets are full and i cant get my hand in far enough to pop a hole. any suggestions on either moving the fuse box of how to get through the firewall? i already searched the web. i need some help here.
appreciate anything.
thanks.
ben
Old Sep 29, 2006 | 09:50 AM
philadd's Avatar
Default Re: amp installation... plz help (98coupeex)
There's one on the driverside that's much easier to access.
Old Sep 29, 2006 | 03:56 PM
skingfreak's Avatar
^^^ as stated above, there is a good sized one on the drivers side, you will have to move some of the "foam" on the fire wall to accsess it, but its just a flap. You can see through the engine bay, its on the left side of the brake master cylinder pretty high up on the fire wall. I ran 1/0 gauge through it no problem. Just make sure you use a gromet, and put an inline fuse before the fire wall. good luck
Old Sep 29, 2006 | 09:18 PM
BlUAc's Avatar
Default Re: amp installation... plz help (skingfreak)
well I did was drill a hole through the fire wall right above the kick panel for the ecu it came out right under the charcoal canister then I got a grommet and put it in and it was all gravity
Old Oct 1, 2006 | 04:10 PM
98coupeex's Avatar
Default Re: amp installation... plz help (BlUAc)
appreciate the help
Slo_Accord
Audio / Security / Video
13
Oct 8, 2007 09:01 PM
Booz
Mar 28, 2007 09:29 AM
casmello
Oct 6, 2005 10:41 AM
GuestStar
Jul 31, 2005 08:53 PM
InTeGrA_bLazEd
Sep 11, 2003 10:32 PM
