Chicago & Illinois: FS/FT WTB, October 2006 -Haloween Bitches
Old Sep 29, 2006 | 04:55 AM
Mooneyes13's Avatar
Default Chicago & Illinois: FS/FT WTB, October 2006 -Haloween Bitches
Chicago & Illinois: FS/FT WTB, October 2006 - Haloween Bitches
Some of you can acutally go out as yourselves now
FS/FT: Flat Black Fat fives on 195/55/15 Potenzas $300
Old Sep 29, 2006 | 05:26 AM
d16rice's Avatar
Default Re: Chicago & Illinois: FS/FT WTB, October 2006 -Haloween Bitches (Mooneyes13)
list below
Old Sep 29, 2006 | 05:48 AM
explictness's Avatar
Default Re: Chicago & Illinois: FS/FT WTB, October 2006 -Haloween Bitches (d16rice)
up
Buy my CRX!!!! i don't want my honda anymore
Check Sig
Old Sep 29, 2006 | 05:55 AM
Akiraboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mooneyes13 &raquo;</TD></TR><TR><TD CLASS="quote">Chicago & Illinois: FS/FT WTB, October 2006 - Haloween Bitches
pssh, I've been all year
In!
Old Sep 29, 2006 | 06:36 AM
paopao's Avatar
Default Re: Chicago & Illinois: FS/FT WTB, October 2006 -Haloween Bitches (Akira_)
I need this car gone.
http://hondamarketplace.com/zerothread?id=1748868
Also have,
89 CRX Si driver's seat w/small holes and ripped bolster - $30
USDM ITR pistons w/wrist pins - $150
Bare D16Z6 block w/no crank - $30
Old Sep 29, 2006 | 06:58 AM
JDM EJ1 95's Avatar
there is 25k into the car with receipts to prove it.. dont lowball me..
<FONT SIZE="7"><FONT COLOR="RED">22000 FIRM OR TRADE</FONT></FONT>
In light of recent family matters me and my brother in law have decided we might have to sell this beautiful car. I am very sad to maybe having to part with it as we havent had much time with it.. but some things are just more important and it will give me a chance to finally go to school.
anyways.. heres the low down..
the build up thread you all might know.
https://honda-tech.com/zerothread?id=1494644
the car was originally a stock 1995 civic EX coupe with 170k on the Odo.
obviously thats not the case anymore. the car is basically brand new now..
i will post a full spec sheet later today as i am at work right now and cant. but heres some pics to get this rolling..
Preferrably i would like to sell it strait up.. but i will also take a trade.. top of my list is an S2K(02/03) OR A older s2k + cash.. i would at least need 6k in cash.. im open for a lot of things so just ask..
DONT lowball me.. Its insulting.. if you had any idea how much time and money i spent on this car and how many hours of hard labor went into it.. you wouldnt dare to try.. if you lowball me i wont consider any of your later offers as you will be pushed out of my people to deal with list.
The car will go to a good home.. the only reason im selling it is because i HAVE to.. therefor it will be with someone i know will take awesome care of it as i would.
the car has only been in rain once... (on way back from a meet.. got caught in some rain) it was washed as soon as it got home..
it ahsnt stayed 1 night out of a garage
ive only driven it about 1500 miles since i built it and i have alreday done an oil change. mobile 1 and a OEM honda filter
Specs and pics.
Engine/drivetrain
-K20a2 out of a 02 Type S RSX 6 speed trans with 33k ($4000)
-Hondata Kpro ECU($1100)
-DTR/SSR fab 4-2-1 race header($1150)
-Golden eagle fuel rail($140)
-Aeromotive Fuel pressure regulator($140)
-Russel fuel lines and fittings ($200)
-hasport hose insert ($40)
-brand new oem honda water temp sending unit and fan switch($40)
-Black coil cover off element($20)
-Custom painted gold Valve cover
-Brand new slave cyl($60)
-walbro 255lph pump($110)
-Custom short ram intake($100)
-Spec stage 4 clutch (6 puck sprung)($400)
-OEM axle combo
-suja 1 clutch line($40)
-Hasport K eg mounts($640)
-hybrid racing conversion harness($350)
-karcepts Shifter box kit($150)
-karcepts FPR mounting bracket($20)
-3 inch kteller piping kit($250)
-vibrant 3 inch flat black oval muffler($140)
i might keep this on the car.
-85 shot Wet direct port nitrous kit NOS brand ($750)
ive only sprayed the motor less than 10 times and only at the track.... a few times on the street.
-Suspension/wheels/ tires
-Front omni 12k sports($350)
-Rear Omni drag Coilovers($500)
-Front omni upper control arms($170)
-omni rear shim kit ($15)
-Rear omni LCAs($200)
-Full-race traction bars($350)
-All bushings replaced with Energy suspension units($140)
-front wheel bearings replaced ($100)
-tie rod ends replaced($100)
-Wheels are Spun supermesh in 15x7 ($480)
-TIRES ($500)
Front tires BFG 225 50 15 Drag radial
tires rear BFG 225 50 15 Traction kd
-car was aligned to a -1 degree camber all the way around i forget the toe.. i think it was .2 degrees toe in.
Brakes.
Rear disc conversion from a integra GSR($200)
Brembo x drilled and slotted rotors all around ($300)
pbr axis ultimate pads all around($100)
brand new rear calipers and hardware.($200)
Body.
--FULL COLOR CHANGE!! to 18L. subaru java black pearl ($6000)
this is one of the nicest jobs on paint ive seen.. it wasin the body shop for 5 months and i made them fix every mistake i found.
-Both quarter panels replaced with oem honda quarter panels..($1000)
THESE ARE HALF CAR PIECES.. NOT PATCH PANELS
-both front fenders were replaced again with OEM honda pieces($500)
-Full-race 6 point cage.. ($600)
-brand new front glass($200)
-Brand new OEM mudflaps($100)
-brand new JDM thin sidemoldings oem honda($150)
-JDM headlights with city lights($150)
-JDM foglights($140)
-JDM Sidemarkers($50)
-ALL MOLDINGS BRAND NEW HONDA OEM.. ($400)
-amber corners($50)
-shaved engine bay (welded holes)
-all bolts in engine bay either refinished or replaced.
-full wire tuck, battery/fuse box relocation
-clutch reservoir reloacted to wiper channel (have stock wipers still if wanted)
Interior/electronics
-heeltoe auto NRG cell battery ($115)
-JDM Type R 6 speed shift **** ($60)
- driver and passenger seat replaced with buddy club slim seats SPARCO BRACKETS($700)
-red suede door panel inserts
- German civic Gauge cluster 220kph ($200)
-whole interior painted same color as car nice and glossy
- 2 Gforce racing 5 point harnesses ($300)
-all power windows/locks/sunroof work perfect
-custom center console with a bit more storage
-full carpet still in.
-i will include the heating/air conditioning unit and blower motor with the car if you want it... i never meant to drive the car in the winter so i didnt need it.
Parts add up to 24,300 without including the price of the car and thats without any labor charges
whored out engine bay shot
foglights only
shots of the paint and reflection..
Email JDMEJ195@gmail.com
AIM: JDM EJ1 95
inquire for phone number.
Old Sep 29, 2006 | 08:16 AM
BJOnewiper's Avatar
purdy
Old Sep 29, 2006 | 10:22 AM
HondaEJ7's Avatar
WTB:
-96-98 civic single din blockoff plate
For sale:
-96-98 civic front ingalls camber kit, used, great condition - best offer
-96-98 civic front bumper primered brand new(email for pic) - $100 OBO
-Sony PSP with a 1gb memory card, and 2 games (Need for Speed and GTA Liberty Cities) used for like a month and now it sits - $300 OBO and can trade for rims or turbo d-series parts
Old Sep 29, 2006 | 10:56 AM
Dirty Underware's Avatar
FS: a set (2) pioneer 12" subs. 600wattage each sub. $70 bucks
Old Sep 29, 2006 | 11:17 AM
gutted's Avatar
Default Re: (Dirty Underware)
FOR_SALE:
$150 EF shell
http://hondamarketplace.com/zerothread?id=1759967
tanabe racing medallion w/ test pipe for EF
$300
d16a6 block w/ pm3 head w/ L3 trans
this swap came out of my crx i bought 2 years ago. supposedly ran but i never tried to get it running, i just yacked it out so its been sitting collecting dust for 2 years. engine turns over but other than that the internal condition is unknown. probably be good for a rebuild. no throttle body, dist, and a couple of other little things
$75 or open to trades
B16A/B17A AEBS headstuds. threads are perfect. includes studs, washers & nuts
$50
aftermarket RSX non TYPE-S B-pipe 2 3/8
$50
offer me ANYTHING for the stuff below, taking up too much space
DX trans, supposedly no grinds. i never ran it
CX engine w/ trans approx 100k
PM9 head w/ manifold
90-91 crx HF front bumper support
88-89 civic DX distributor, i never ran it dont know if it works
pick 2 or more of my stuff by this weekend and ill give you the badboy hookup!!
WILL TAKE TRADES
WANT_TO_BUY:
3 blank ecu chips
96-00 civic coupe STOCK sideskirts
96-00 civic ex gauge cluster, preferably AUTO
1 (one) LS mesh wheel
90-91 crx sideskirts, door moldings & front bumper
Modified by gutted at 12:00 AM 9/30/2006
Old Sep 29, 2006 | 11:22 AM
AlienKrOZ's Avatar
Default Re: (gutted)
wtb: type r cams or any cams that's good for vtec turbo
WTB: 94-01 Integra Black Door Panels non-tweeter version only.
Old Sep 29, 2006 | 11:34 AM
wtb: cheap set of (at least 16) MUTEKI lugs..
Old Sep 29, 2006 | 12:13 PM
Grip's Avatar
BUY my 01 impreza coupe!!!!
search user -whitey- to see the FS ad.
WTB: 97+ CW ITR..must be stock
Old Sep 29, 2006 | 12:37 PM
mexicanstud's Avatar
WTB: Skunk2 Intake Manifold for a b16
need this asap
Old Sep 29, 2006 | 04:25 PM
94sisol's Avatar
Default Re: (mexicanstud)
FS: OBD2B To OBD1 Conversion Harness - $100
Mugen MR5s - $750
WTB: Stock H22 Cams or Type S Cams
Stock H22 Intake Manifold or Aftermarket
Old Sep 29, 2006 | 06:12 PM
soulhassorrow's Avatar
Ok i need these parts gone asap cause im shipping out for the airforce in 2 weeks.
PRODUCT: 17' universal 4-lug Ro_Ja LT5 Neos in championship bronze wrapped in Nitto Neogens with 75% thread left.
CONDITION: 2 tires are perfect, one has some curb rash, and one has a minimal dent on the lip.
PRICE: $400 OBO
PRODUCT: Skunk2 Megapower Catback
CONDITION: Mint
PRICE: $175 OBO
PRODUCT: OEM 94-97 CLear Fog Lights(just lights) attached to a frost white oem half bumper.
CONDITION: One is perfect and the other has an internal crack.
PRICE: $50 OBO
PRODUCT: 94-97 OEM Front Bumper with turn signals
CONDITION: Has a gash on the passenger side and a few paint chips and turn signals are perfect.
PRICE: $40 OBO
PRODUCT: OEM Cargo Cover
CONDITION: PERFECT
PRICE: $30 OBO
MORE TOO COME!!!!
WTB ASAP 2 15' 4x100 steelies with winter tires!!!!
Old Sep 29, 2006 | 07:08 PM
RapeV-8's Avatar
in!
Old Sep 29, 2006 | 07:56 PM
JDM TR Civic's Avatar
Default Re: (igotcrx)
WTB: a 3" R&D thermal turbo exhaust for a 95 EG hatch. Hope somone has this. I am eager to get it. I have the following items to trade as well as cash in hand. Let me know you have it, and if you are interested in anything below to trade +$$ on my part.
**All parts are for sale and trade offers as well**
-complete Zex dry nitrous kit with all hoses, lines, mounts, bottle w/ pressure guage. $350 for a good deal!!
-Set (4) 15" gunmetallic Rota slipstream rims good condition (clean), with set of black gorilla lugnuts w/ key $300
-OEM EG Hood. Off of 95 coupe, will fit 92-95 hatch/coupe. Great condition!! $100
-Cruis control box $25
-Complete a/c system from firewall out from a 95 civic coupe all lines, evap., condenser, compressor. $150
-JDM integra typeR power steering pump w/ bracket will fit all B-series $40
-JDM integra typeR stock cam gears (very clean) $30
-JDM integra typeR torque brackets $15
-integra/civic torque mount inserts $15
-power steering fluid resevoir from 95 coupe (very clean)$10
-dark gray/black rear gsr integra seats, also fit 92-95 civic hatch $60
My email is webs103086@yahoo.com, my AIM s/n is webs103086, and you can PM me as well. I have pictures of all parts at --&gt; http://s111.photobucket.com/al...local.
Old Sep 29, 2006 | 09:10 PM
Default Re: Chicago & Illinois: FS/FT WTB, October 2006 -Haloween Bitches (explictness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by explictness &raquo;</TD></TR><TR><TD CLASS="quote">up
Check Sig</TD></TR></TABLE>
price drop to 800! i don't want this car!
Old Sep 29, 2006 | 10:35 PM
swpdb16's Avatar
Old Sep 30, 2006 | 06:08 AM
pli's Avatar
pli
Default Re: Chicago & Illinois: FS/FT WTB, October 2006 -Haloween Bitches (swpdb16)
fs: ebp si grill. needs a little touch up on the paint. 70obo
Old Sep 30, 2006 | 07:52 AM
.Beaver's Avatar
Bloody Beaver
WTB: front crossmember and power steering rack from a 92-95 Civic with PS or 94-01 Integra.
.Beaver's Avatar
Bloody Beaver
Default Re: Chicago & Illinois: FS/FT WTB, October 2006 -Haloween Bitches (pli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pli &raquo;</TD></TR><TR><TD CLASS="quote">fs: ebp si grill. needs a little touch up on the paint. 70obo</TD></TR></TABLE>
those things sell for $55 new!
Old Sep 30, 2006 | 07:58 AM
Ls91sI's Avatar
Default Re: (soulhassorrow)
pm'd
Old Sep 30, 2006 | 08:12 AM
that_vtec's Avatar
F.S. EF STUFF AND PARTING OUT A 91 ACCORD along with some other crap i dont need....MAKE OFFERS MAKE OFFERS
ef stuff
1 climate controls
almost brand new hatch shocks
stock passenger mirror remover peice
black ''civic''panal that goes between the tails
red ''civic'' panal
the little change holder left of the steering wheel(includes screws)
complete 91 honda accord 4 door(f22)..sitting in the drive way and need it gone
NOTHING has been takin off yet
also some parts on it are
It has a sun roof
AEM cold air intake
DC SPORTS front strut bar
Megan stainless steel racing header..LESS THAN A MILE ON IT
New Exhaust all the way threw
90-91 american products company corner lens
94-95 american products company bumper lens
ALL parts are still on the car just make offers on what you want and ill let you know.
IM me some offers. i have to many parts taking up space in the spare bedroom garage and driveway
other car stuff i have
eg hatch cover
eg tails
90 integra tails
i also have for xbox battle field 2
let me know
