D15B Vtec Problem
Ok i have had a problem since i bought the engine.
at a constant speed the engine will seem to cut out, loose power unless i slam on the gas.
so i messed with the O2, did nothing
then i changed the IAC, that fixed my idle problem but it still looses power.
what next?
im thinking of replacing the fuel filter, spark plugs, cap and rotor. i need to know what spark plug/cap/rotor off of what engine i should buy for the D15B VTEC. I am also assuming that i just buy the fuel filter for my car since i never changed it.
what next?
i had a similar problem... my car would bog down then if i gave it gas it wouldn't be as bad...
you should try replacing the cap/rotor/spark plugs and wires...
when they get worn out then you dont get the spark it needs... replacing the fuel filter wouldn't be a bad idea either...
i think you can use cap/rotor off a D16z6 if i'm not mistaken... even though the distributor bolts up different than the D15B.
Its either all D-Series the same or is it all VTEC d-series are the same... << can somebody back me up on this?
Alright i changed the cap rotor plugs wires fuel filter and did an oil change.
the car runs 100% better, around town untill i get on the highway, the civic warms up and im doing a constant speed is when it will still loose power and i have to slam on the gas to get going again.
though it needed all that stuff, it didnt fix my problem.
