S2000 CD Player install into 1991 Civic
Old Sep 28, 2006 | 10:37 PM
jisu009's Avatar
Default S2000 CD Player install into 1991 Civic
Few questions here.
I would like to get this to work without hacking the factory plugs off my existing harness in my 1991 Civic. I purchased a CD Player out of a 2003 s2000 because I want to maintain that factory look.
Is there a plug adapter that will allow me to plug in the s2000 deck into my existing harness without hacking things up?
Also. I purchased some Infinity 2-way speakers and want to mount them in my front doors....however the existing "speaker pod" that is currently mounted to the door won't allow these speakers to fit. It's also pretty hacked up and needs replaced.
Would I replace the pod with factory or aftermarket ones? Does anyone know a good source for these "pods?"
THanks guys!!
Old Sep 29, 2006 | 12:10 AM
turboekcivic's Avatar
Default Re: S2000 CD Player install into 1991 Civic (jisu009)
yeah get the reverse harness for the stereo which is 98+ and put it with the older more rectangle one
Old Sep 29, 2006 | 07:59 AM
B18C_EJ8's Avatar
More specifically, you will need a (Metra Part #'s) 70-1720 harness to plug into the car's wiring. Then, get a 71-1721 harness and wire both plugs toghether, and it'll be plug & play.
You'll connect both harnesses together matching color to color.
Mounting the new radio, however, might be more of a challenge.
Old Sep 29, 2006 | 11:14 AM
jisu009's Avatar
Default Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">More specifically, you will need a (Metra Part #'s) 70-1720 harness to plug into the car's wiring. Then, get a 71-1721 harness and wire both plugs toghether, and it'll be plug & play.
Mounting the new radio, however, might be more of a challenge.</TD></TR></TABLE>
Thanks man.
I was thinking that the new radio would slide in just like factory. It's just a single DIN radio right?
Old Sep 29, 2006 | 08:39 PM
Default Re: (jisu009)
yeah
Old Sep 29, 2006 | 10:51 PM
jisu009's Avatar
Default Re: (turboekcivic)
So the s2000 cd player should fit right in no?
Old Sep 30, 2006 | 10:54 AM
fcm's Avatar
fcm
Old Fart
A 2003 s2000 HU uses a different mounting system then a 1991 Civic. 94
Old Sep 30, 2006 | 01:04 PM
jisu009's Avatar
Default Re: (fcm)
but will it fit dimentionally? If it will slide in there I can make the rest work....
Old Oct 1, 2006 | 10:06 AM
fcm's Avatar
fcm
Old Fart
Yes it will. 94
hialeahzbg
Honda S2000
Jan 16, 2007 07:08 PM
Kangolbrand
Audio / Security / Video
Mar 10, 2006 05:46 PM
2nxcrx
39
Dec 13, 2005 09:21 PM
DCivic00
Nov 23, 2005 06:10 PM
NW94RS
Honda S2000
Jun 23, 2004 12:05 PM
