ITB Daily driver anyone?
Old Sep 28, 2006 | 10:23 PM
SF_EF8's Avatar
Default ITB Daily driver anyone?
Been looking to get a set of TWM ITBs for my LS/VTEC coupe, which is my main source of transportation, and i was wondering if any of you daily drive ITBS and if so what precautions do you take? Filters, Screens, Custom manifolds, or just be straight gangsta and just got them naked.
Also, a buddy of mine is looking to get a set as well for his 00 civic si, since we can get them for a better price for 2 locally. Yet he has basically a stock motor, he does have a DTR header, apexi catback, LSD tranny, clutch with flywheel, and a set of ITR cams he might throw in if he decides to.
My question is, will he benefit from them, the ITBS do come with 310cc injectors, so i'm wondering if it will hurt him performance wise or actually notice somewhat of a difference.
thanks in advance
Old Sep 29, 2006 | 09:57 AM
SF_EF8's Avatar
bump
Old Sep 29, 2006 | 10:03 AM
Nick M's Avatar
Default Re: (SF_EF8)
no bumping
Old Sep 29, 2006 | 10:46 AM
D-Rob's Avatar
Default Re: (ENM)
Alot of people I know who have ITB's have little filters on them when driving on the street.
Do you really need ITB's, though? Have you researched the proper size for your setup? There is such a thing as too big of an ITB.
For a street car, I would much rather have the peace of mind that comes with a plenum-style intake with a single TB.
Old Sep 29, 2006 | 06:39 PM
machine4321's Avatar
drove on my diy for a year , not a problem drive-ability was great if not better then stock (much more responceive) my diy pissed me off at times but it was my own falut.
even got 25mpg+/- on the hiway
Old Sep 29, 2006 | 06:42 PM
SF_EF8's Avatar
thats good to hear, what was your setup?
Old Sep 30, 2006 | 07:25 PM
soulpwr's Avatar
Default Re: ITB Daily driver anyone? (SF_EF8)
I daily mine, no filters but i change the oil frequently. Throttle response is much better than a manifold but sticking throttle gets irritating. Stand alone fuel management tuned by tps takes care of that though.
-Twm 50 mm on a b20vtec
Old Oct 1, 2006 | 01:51 PM
gsxr1000 itbs spaced out on a custom flange/runners
at tthe time it was a f20b in my 95 accord , i sold them to go bigger but it hasnt funded up yet lol .
it was pretty much stock . but still made a noticeable difference
Old Oct 1, 2006 | 02:28 PM
92TypeR's Avatar
FSAE
Default Re: (machine4321)
You can make equal to, if not more power (area under the curve & peak) with a properly sized intake manifold and tb. FYI.
You will need some sort of tuning solution that has full resolution tables, hopefully one that has the option for alpha-n tables or a mix of TPS/MAP. Crome Pro is cheap and works great. We've also run PowerFC on ITB's and they run fine.
However, keep in mind that TWM's are not ready to go on the car 'out of the box'. You will need a second throttle return spring to help with throttle stick, and you will need to tap each runner to feed a separate vacuum manifold to run your MAP sensor off of.
FWIW, Jenvey ITB's will make more power everywhere compared to TWM's, even with 2mm smaller plates.
Old Oct 2, 2006 | 04:40 PM
soulpwr's Avatar
Default Re: (92TypeR)
You can buy twm's with a vacuum accumulator which eliminates the need to build one or tap anything. It works fine on my car but i remember hearing about it causing a problem on car at rage/hookups. I installed them right out of the box and fired it up on a stock ecu no problem. but thats me, maybe i'm just lucky.
Old Oct 2, 2006 | 05:58 PM
98TEG2NV's Avatar
itb are the ****, i have a setup. pmed
Old Oct 2, 2006 | 09:49 PM
92TypeR's Avatar
FSAE
Default Re: (soulpwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soulpwr &raquo;</TD></TR><TR><TD CLASS="quote">You can buy twm's with a vacuum accumulator which eliminates the need to build one or tap anything. </TD></TR></TABLE>
The problem lies with the integrated accumulator. The MAP signals are distorted by the closest runner. Night and day difference when switching to a separate log/manifold. Had to do this to three different setups using the new TWM's.
Old Oct 2, 2006 | 09:51 PM
gldndrgn14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">
FWIW, Jenvey ITB's will make more power everywhere compared to TWM's, even with 2mm smaller plates.</TD></TR></TABLE>
its just a better design. they design it more tailored to the head and engine than twm does. twm just uses a basic straight runner. if you compare the jenveys to twms, from both pr3(b16/type r head designation right?) heads and p72 heads, the p72 manifold angle and runners are different than the pr3 from jenvey, and the twm is the same just different flange. jenvey puts more thought into their r&d is how i see it. and no problems sticking with traditional standalone tbs vs cast in tbs in the twms with the linkage contraption on my twms.
Old Oct 2, 2006 | 10:00 PM
98TEG2NV's Avatar
aight so im bout to put my TWM itb setup on my car so will i need to get it tuned or can it run fine on the stock ecu. plus its my daily driver
Old Oct 3, 2006 | 07:23 AM
thats a no go for stock ecu .
managment is a MUST with itbs , its so different then a manifold in the way it acts. your car will flood , foul plugs and **** you off . if it even starts.
get it tuned
Old Oct 3, 2006 | 08:42 AM
Black R's Avatar
25 Year Member
daily driver with toda itb's here.....
Old Oct 3, 2006 | 11:03 AM
98TEG2NV's Avatar
well i have the hondata s200, can anybody tune it around my way. richmond, va
Old Oct 3, 2006 | 12:48 PM
Black R's Avatar
25 Year Member
Default Re: (98TEG2NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TEG2NV &raquo;</TD></TR><TR><TD CLASS="quote">well i have the hondata s200, can anybody tune it around my way. richmond, va</TD></TR></TABLE>
does s200 have alpha-n or tps tuning maps? it didn't the last time i checked, so that'll suck.....
you'll need crome, neptune, aem ems, or s300 to get those itb's to their potential.....!
Old Oct 3, 2006 | 11:35 PM
92TypeR's Avatar
FSAE
Default Re: (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">you'll need crome, neptune, aem ems, or s300 to get those itb's to their potential.....!</TD></TR></TABLE>
x2
Since you already have the S200, Hondata might give you an upgrade for cheap. Otherwise, Crome is free.
Old Oct 4, 2006 | 06:06 PM
type_r_556's Avatar
Jenvey ITBs w/ AEM....idles,drives like stock
jksmith
Nov 3, 2008 07:41 AM
dtbrown78
Nov 24, 2006 06:34 PM
IntegraLs94Cam
Jan 28, 2006 07:58 PM
