prelude type-s cams wtih H22A cam gears
Old Sep 28, 2006 | 09:44 PM
thevtecnician's Avatar
Default prelude type-s cams wtih H22A cam gears
What do I have to do to install these in my 92 jdm h22a?
Old Sep 29, 2006 | 01:02 AM
preludedriva's Avatar
Default Re: prelude type-s cams wtih H22A cam gears (thevtecnician)
im pretty sure all you gotta do is take the valv cover off and replace the old with the new hanes manual has walk through
Old Sep 29, 2006 | 01:11 AM
All-Motor-Junkie's Avatar
^^ what he said, make sure to not loosen the timing belt and only take off the valve cover bolts, then u can slide the cams out the side, its awesome
Old Sep 29, 2006 | 08:07 AM
bluedlude's Avatar
Default Re: (All-Motor-Junkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All-Motor-Junkie &raquo;</TD></TR><TR><TD CLASS="quote">^^ what he said, make sure to not loosen the timing belt and only take off the valve cover bolts, then u can slide the cams out the side, its awesome</TD></TR></TABLE>
you cant just slide them out the side! damn.
you are gonna have to take the valve cover off. take offf the cam cover plates. then loosen up the timing belt and loosen up the cam gear bolts if you plan to reuse them(its easiest that way). then pull the belt offf the gears. take off the cam covers and remove some seals and such. now replace with new cams and go in reverse order pretty much . sorry i dont know the exact name for the parts, but i actually know how to do it.
make sure you do it at TDC so its easier to get the timing aligned again.
HONDA RR
Apr 21, 2005 11:59 AM
B16A2-EM1
42
Jun 25, 2003 03:12 PM
Propulsion
Mar 23, 2003 10:37 AM
joemama
Jun 12, 2001 08:45 AM
