water leak by ecu????
ok i got a 95 integra and water leakin in my car right where the ecu is at. where could this be comin from. the last leak i had came from the roof squiter for the back window but i fixed that (shaved it). now i got this leak. what could be causing this?
my girl's MDX leaks in that same spot. i'm not sure of the exact name of them, but the water channels that run from the windshield to behind the fender area can get clogged( just from what i'm told)so maybe that applies to other Honda/Acura's. Also, Acura told her it was probably her sunroof but they said they didn't fix things like that(Whether or not they even checked it). I'd check the both of them and if thats not it then check your seals on your door and panel.
ya im gonna have to check that when it decides to stop rainin. its like a never ending battle with this car if it aint one thing its another. most of the problems i fixed but this leakin water drivin me nuts
besides the door seals, door panels, sunroof, and water ducts, i'd check to see if the windshield is sealed all the way around. i've seen some pretty bad windshield jobs ( i've replaced mine twice) and last time the place that did it did a really sloppy job. it didn't leak but it probably should have...oh and check under and behind your dashboard. if u feel moisture behind your dash than chances are your windshield could be the problem.
a buddy of mine had the same problem it may be a leak in your raditor line the third raditor line extending to the firewall you can bypass it only thing you lose is hot air flowing through your car when its cold
i did bypass the heater core hose b/c the heater core went bad and i didnt want a puddle of antifreeze in the car. ya the seals around the windshield look like it would time to replace. im gonna have to check all the spots u guys told me and hopefully i can find and fix the problem. ill do that after i get off work tonight
Mine leaks in the exact spot you describe. If you pour water down the windshield you can see water running down behind the ECU. On mine the water is somehow finding its way in through the frame rails. The only way I know of to fix it is to seal up the frame rails with some expanding foam. Otherwise, there it's impossible to get access to where the water is coming in.
Check the liquid to make sure its water. Get a little on your finger and taste it, it won't hurt you. If its sweet its not water and antifreeze, therefore start checking hoses as the heater core rarely goes bad.
If its water a common but unknowen problem is a stupid 25cent gromet that always goes bad. People will run around trying to find the problem but this is mostly the cause. Remove you wiper arms, and the plastic piece underneath. Where the clips go there is a small gromet that looks like a baby condom, literally less than an inch. Pull them out and inspect it an gauranteed they are leaking, replace them and use a little silicone and gaurantee it won't leak water anymore.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_grinder »</TD></TR><TR><TD CLASS="quote">If its water a common but unknowen problem is a stupid 25cent gromet that always goes bad. People will run around trying to find the problem but this is mostly the cause. Remove you wiper arms, and the plastic piece underneath. Where the clips go there is a small gromet that looks like a baby condom, literally less than an inch. Pull them out and inspect it an gauranteed they are leaking, replace them and use a little silicone and gaurantee it won't leak water anymore.</TD></TR></TABLE>
That's only on G2 Integras, G3's don't have anything like that so unfortunately the fix is not as easy, if it's a leak like mine.
i wish it was as easy to fix as just a gromment and silicone. man i got to find this leak b4 it ruins my ecu. it looks like it has been doin it for a while i just now saw it after switchin my ecu out. good thing i was feelin lazy that day and didnt put it all back together. if i did that i probably would not have found out til it burned up my ecu
Back when I was trying to fix my water leaks, I took my ECU bracket off and found it like this:
Mine still leaks, but I don't worry about the ECU too much. The water just runs down the side and down onto the floor under the carpet, and I keep a couple of towels under the carpet and change them out every so often. It's done the trick for over a year now because I'm too lazy to pull the fender off and inject that expanding foam up inside the frame rails. Maybe one day I'll get to it.
ya that what mine looks like. i was lookin around and i noticed on the passenger side behind the fender where the rubber casin is for the wires i noticed that there was added wire running throug there. it appears the previous owner had re ran the speaker wires on that side and he had made a hole in that rubber piece to bring the wire in side the car. could that be the reason its leakin?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc4teg95 »</TD></TR><TR><TD CLASS="quote">ya that what mine looks like. i was lookin around and i noticed on the passenger side behind the fender where the rubber casin is for the wires i noticed that there was added wire running throug there. it appears the previous owner had re ran the speaker wires on that side and he had made a hole in that rubber piece to bring the wire in side the car. could that be the reason its leakin?</TD></TR></TABLE>
I don't believe so. Normally when water runs down the windshield, it runs down either side below the cowl trim, and down behind the fenders, to empty out down by the front mudguards. Once it gets under the cowl trim, it runs out through this hole:
Then it's supposed to come out at the top arrow, and drip down behind the front wheel fender liners (bottom arrow is where the front sunroof tubes drain out):
I noticed water running down the side behind the ECU bracket (top arrow), sitting on this little ledge (bottom arrow) then spilling onto the floor below the carpet:
So I pulled the whole dashboard out and found the water coming in this area:
After pulling out the A/C blower motor, I found this hole in the structural seam sealant, which I filled with silicone, topped that with JB Weld, then topped that with more silicone:
Well that sealed up that hole, but then water still found its way in through the hole in the side where the wire harness comes through. There's really no way to seal that up, I don't think, so the only thing I can think of is that the water is finding its way INSIDE the frame rail, then running down and into the car. And the only fix I can think of for that, without taking a blowtorch and cutting the frame rails apart
is to just fill the frame rail with expanding foam sealant. I just haven't gotten around to doing it on my car yet.
is it common for integras to have water leaks every where. it seems like all year integras leak water.could it be a manufactor defect or something?
I've been having the same problem on my '96 Integra with rain dripping into the passenger footwell. By running a hose with the nozzle set to a narrow, slow stream around the windshield, firewall, door frame and roof, finally discovered that the water was entering from the point on the roof where the rain groove goes under the windshield molding down toward the A-pillar. I just sealed the joint with silicone and will wait for the next rain to find out if it worked. I could retest with the hose, but at the moment the floormat is still drying on the line, and I've got all the windows open for the carpeting to air out.
the only spot mine used to leak was the trunk. then i figured out that the taillights were somehow leaking through so i got a set of 98-01 tails. killed 2 birds with one stone. water damage is a pain in the ***. i hoped my earlier info helped. good luck.
i have a 91 integra and i have a water leak too, every time it rains it floods... i dont know where it comes from but the passenger seat and the carpet gets soaked. my defroster and heat doesnt work either and i think its because of the leak. let me know when you figure out whats going on
ARGGG I HATE THIS STUPID CAR I RIP EVERTHING APART INCLUDING THE FRAME RAILS SILICONE EVERYTHING N THE **** STILL LEAKS OMG IM GONNA RIP IT APART ONE MORE TIME AND IF IT DONT STOP IM JUNKING THE CAR
my fvcking integra was leaking in the same place!when it rains it becomes a lake lol. There is a plug in the firewall were most people run the amp wire thru cause its closer to the battery! mine was missing because i was using mine as a plug i took my rear window wiper out nd i put that there. but i fixed the leak with a lil duct tape lol.
ohh man am i on the same boat as most of you ...i just cant figure it out it soaks up the passenger side carpet and floor mat and worst of all it smells like old water after it rains in the car ...not much of a pleasent smell imma take it apart and see if the drain tubes are clogged or what
im convinced that the water is coming in around the air inlet where the seems are, from what i saw with the fender off it doesnt make sense that that much water is getting in just by spalshing up against the side from the drain
