what would make my fuel pump. not prime?
Old Sep 28, 2006 | 08:22 PM
superhatchbackbros's Avatar
Default what would make my fuel pump. not prime?
hey i recently am trying to get my d16y7 turbo 89 hatchback started and i heard my new walbro 255lph hp fuel pump prime 2 times and tried to start it. didnt start then i went to try again and the fuel pump didnt prime, and ever since.. so i was wondering what could have made it not work? like bad wire harness? or a fuse or a need proper grounds i was told under the hood? if anyone knows anything i can try or maybe know the problem please let me know thanks.
Old Sep 28, 2006 | 08:51 PM
Bob_760's Avatar
Default Re: what would make my fuel pump. not prime? (superhatchbackbros)
Sounds like the main relay, the main relay primes the fuel pump.
Old Sep 28, 2006 | 09:05 PM
Tippyman's Avatar
Default Re: what would make my fuel pump. not prime? (Bob_760)
There is also a fuse called the "Alternator Soldenoid" or sumthing like that. Random *** name, but the FP goes thru it. mine blew and the FP didn't prime.
Old Sep 28, 2006 | 09:08 PM
NikoZai's Avatar
Default Re: what would make my fuel pump. not prime? (Tippyman)
haha, I dunno about the alternator fuse causing that. But definitely check ALL your fuses. After that, there are a few wires to troubleshoot. I think it's covered in the CRX workshop manual located here:
http://www.norcalcrx.org/library/
Old Sep 28, 2006 | 09:22 PM
Tippyman's Avatar
Default Re: what would make my fuel pump. not prime? (NikoZai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai &raquo;</TD></TR><TR><TD CLASS="quote">haha, I dunno about the alternator fuse causing that.</TD></TR></TABLE>
Trust me, I was stuck outside my doctors office for an hour trying to figure that **** out. Turns out my fuel pump wiring was grounding out and blowing the fuse. once I got that sorted out, it started right up.
SPUNKYMUNKY
11
Mar 27, 2015 03:58 PM
Jap_Spec_Imports
Sep 10, 2008 01:43 PM
snzh22
Aug 8, 2007 04:53 PM
progressivedrunk
Oct 19, 2003 05:45 PM
