is engine heat killing my starter?
Old Sep 28, 2006 | 08:13 PM
saikouEF8's Avatar
Default is engine heat killing my starter?
when i drive my car it gets to the normal operating temperature and when im driving the car harder it getts hotter (in the engine bay, not the temp gauge), everything is fine but im starting to think my starter is taking a **** due to heat soak.... ill run in a store after driving on the highway or spirted driving and go out to my car and it wont start for like an hour. wont even crank at all... fuel pump turns on... blah blah.. electrical is fine... but just wont crank for like an hour or so until after its cooler i assume... wtf is this all about? doesnt seem like a main relay thing cuz here its not hot outside anymore. comments?
Old Sep 28, 2006 | 08:18 PM
rdssk8rcs1's Avatar
Default Re: is engine heat killing my starter? (saikouEF8)
how much work do you have done to your car?
could be that your plugs are getting too hot, try getting colder plugs and see if the problem stops
Old Sep 28, 2006 | 08:28 PM
saikouEF8's Avatar
Default Re: is engine heat killing my starter? (rdssk8rcs1)
not much work ,just intake header exhaust ported mani new dizzy and cap walbro pump plugs are hotter and brand new, new ngk wires... thing is, this just started happening this week. i just swapped this motor in july. its all pretty much new stuff.... except the starter and the alternator.. which is why i was wondering if it was the starter being heat soaked... i couldnt even touch it
99Ek_Fred
Jul 26, 2018 11:53 PM
munchlax
Jun 16, 2011 06:40 AM
sprtbiker
Oct 15, 2009 05:57 AM
zennx2k3
Sep 23, 2008 05:38 AM
lilxvtecxpwr
Jan 15, 2003 11:21 AM
