engine <<rattle>> . please help.
Old Sep 28, 2006 | 05:37 PM
juandela's Avatar
Default engine <<rattle>> . please help.
99 prelude base
50k
recent 5w30 oil change
engine rattles mostly under decel. strange part is that it does it between 1200rpm and 500rpm. when it settles into idle at 5k (when warm) the rattle goes away. it's starting to do it during accel or even constant rpms. on cold idle it doesn't happen because idle is around 1200-1300. lately it doesn't happen at all when the car is cold. it seems to be getting slightly worse when warm.
sounds too deep to be a "tick". almost sounds like a rattling heat shield but it seems to be coming from internally and from the top of the motor.
car seems to run fine.
any help would be greatly appreciated.
Modified by juandela at 4:45 PM 9/29/2006
Old Sep 28, 2006 | 05:55 PM
so lazy's Avatar
Default Re: engine <<rattle>> . please help. (juandela)
try to get your valves adjusted... and check your front and back heat sheild on your header... if you have stock headers
Old Sep 28, 2006 | 06:02 PM
juandela's Avatar
Default Re: engine <<rattle>> . please help. (dc2-guy)
yup, stock headers.
i'll check that out.
does the valve adjustment theory conform with this strange range of rpm's that produces the sound? i would think that mis-adjusted valves would make a noise at all rpms.
thanks for the help.
Old Sep 28, 2006 | 06:04 PM
so lazy's Avatar
not always... i've had a valve sound at idle and then when driving and let out it would do it but when reving up it wouldn't.. sometimes...
Old Sep 29, 2006 | 08:45 AM
juandela's Avatar
okay. interesting.
just talked to the local honda service manager and he's at a loss.
he said, though, he doesn't see many timing chain tensioner issues in this motor. strange, here in internet-world i see it talked about as it is were common.
nicklp60452
Jul 14, 2008 02:53 AM
jmv38
Apr 10, 2006 01:05 PM
no2unenolife
Mar 22, 2006 10:42 AM
uneek4dr
Feb 6, 2006 01:28 PM
Black Sheep
Apr 18, 2002 09:40 AM
