car takes forever to start after clutch/flywheel install
Old Sep 28, 2006 | 01:33 PM
ragethemachine86's Avatar
Default car takes forever to start after clutch/flywheel install
as title states the car takes a good 4-5 seconds to start. i did the install myself but i still have much to learn about motors. wat could have caused this problem? it drives perfect.
Old Sep 28, 2006 | 01:38 PM
roller3804's Avatar
Default Re: car takes forever to start after clutch/flywheel install (ragethemachine86)
did u bleed the clutch really well? And have u checked the battery charge?
Old Sep 28, 2006 | 02:38 PM
Revi's Avatar
Default Re: car takes forever to start after clutch/flywheel install (roller3804)
Check your connections to your starter again, also like stated above, make sure you battery is good.
HypL
Feb 19, 2015 11:56 AM
LU!SKEY
Mar 9, 2011 09:23 AM
Circa
Aug 3, 2007 04:49 AM
YodajdmEK4
Nov 15, 2005 03:10 AM
t3to4e
Dec 14, 2003 08:40 AM
